| Connect Nav+ CODE I am still waiting for NavTeq to reply about maps for South Africa, but in the meantime I saw someone selling a unit on a german site. I asked if he had the CODE and he replied... "I don`t have the Mastercode for the CN+, but it isn`t required to get the CN+ working. All you have to do, is to connect the CANBUS A-Line first, after that connect the CANBUS B-Line. With this you override the Mastercode on the CN+." Is that correct? Surely it is required, or anybody stealing it could also use such a simple method... (not that I know what he is talking about, but obviously its something you do when installing it, and it seems a little bit too easy) Tx!
| All Hail the Woodsman | Re: Connect Nav+ CODE I've never had to enter a code on my Connect Nav+ when disconnecting the battery or even when fitting a CDC, so it may be true.
__________________ Fiat Bravo T-Jet Sport / Strada 130TC (currently undergoing restoration) www.strada130.com | ||
| | #3 | ||
| Banned | Re: Connect Nav+ CODE You only enter a code that YOU have selected from the setup menu.
| | #4 | |||
__________________ Stilo Abarth Selespeed 3dr, Broom Yellow (Nov '03) Ulysse 2.0 16V EL, Forest Green Metallic (Oct '01) | ||||
| | #5 | ||
| Re: Connect Nav+ CODE You actually have to enter a 4 digit pin code. there might be models out there which don't require that though (different fiat part no's...) The thing with the can bus lines is correct though. works exactly that way. best, lars.
__________________ 5d 2002 Stilo 1.2 in stone gray, Abarth dash + Connect NAV+, a few more goodies, just ask =) nice car! 2005 Punto MkIIb 1.4 Emotion fully loaded. | |||
| | #6 | ||
| Re: Connect Nav+ CODE who makes the cn+?
__________________ Cars owned 1997 - 2002 Seat ibiza, 2002 - 2004 Punto HGT 2004 - 2006 - Stilo JTD (remapped) 2006 - Rover 25IL / Peugeot 206 sport / Subaru 2008 ? could be GPS or MCS | |||
| | #7 | ||
| Re: Connect Nav+ CODE It's Blaupunkt-designed and manufactured by Magneti Marelli.
| | #8 | ||
| 5vp3r m0d | Re: Connect Nav+ CODE I thought it was Visteon?! Although I am aware that the CN+ in the Ulysse is made by Magneti Marelli.
__________________ Electroclash Panda 100HP ![]() Red brake calipers - done / Red highlights on engine cover - done Red GSR kit - done / Red badges - done / Cobra springs - done ![]() ![]() | ||
| | #9 | ||
| Re: Connect Nav+ CODE I also read somewhere that all the Stilo headunits were by Visteon.
| | #10 | ||
| Re: Connect Nav+ CODE Magneti Marelli make the CN+ other stilo radios are made by Visteon
| | #11 | ||
| 5vp3r m0d | Re: Connect Nav+ CODE Thanks for clarifying my misunderstanding Found this on the MM site:
| | #12 | ||
| Re: Connect Nav+ CODE Help me please! I bought Fiat Stilo 2002 with Magneti Marelli Connect Nav+, but I haven't code. I made all steps as described here: http://freenet-homepage.de/fk2000/cn...cn+_einbau.htm but it doesn't work ![]() I disconnected pin 3 first, switch ignition ON, but spidometer not blinked I try to disconnect pin 1 - without effects CN+ worked until ignition is OFF. If I switch ignition ON - CN+ write "Enter Code" Maybe I can do anything else?
| | #13 | ||
| Glutton for Punishment | Re: Connect Nav+ CODE Ok, is this a factory installation or an after-production job? If by "Pin 1" and "Pin 3" you mean CAN-A and CAN-B, doing so is pointless as they are both needed for the CAN-BUS to work at that node.
__________________ 07 Bravo TJet Sport, Maranello Red Factory Options: Dual Zone Climate, 18" Alloys Retrofitted: Armrest with conditioned foodbox, Stainless Kick Plates Sister's: 06 Grande Punto 1.4 Dynamic, Crossover Black, Red Badge Conversion | ||
| | #14 | ||
| Re: Connect Nav+ CODE 1. Factory 2. Yes. These CAN-BUS. I try to disconnect both pins 1 and 3 and CN+ worked with ignition ON, but management on a rudder did not work
| | #15 | ||
| Re: Connect Nav+ CODE Addition info: FIAT Stilo 2.4i 20v 2002 VIN: ZFA192000*00099463 Numbers on CN+ (back cover): Magneti Marelli 0681 500189440130880 735297003 Please help me.
| | scrod | Stilo | 3 | 24-02-2005 16:16 |
| New Ulysse Connect Nav + | Stu DemonD | Ulysse | 126 | 18-06-2004 01:16 |
| | Mikas | Stilo | 7 | 30-04-2004 02:38 |
| | coolchef | Stilo | 5 | 04-09-2003 04:46 |
| Connect Nav - How do I Play[?] | Gladiator111 | Multipla | 1 | 06-07-2003 00:22 |
