| strange little noise Ok i know my stilo is new and its going to make some funny little noises as it loosens up a bit. But this one just started today and it is minor but im just wondering if anyone has had this as it seems a little strange. On ignition only, fans off there seems to be this very slight droning sort of computer fan type noise coming from behind the dash board. When i turn the ignition of it seems to slow down and fade out to the click where the interior light fades in. Is there any sort of little cooling fans in the dash or anything like that which might be causing this?...could always be a cooling fan in the engine bay...but the temp was normal. Do you think the noise i am hearing is the start of somthing to be worried about or is it just one of those noises. Also my handbrake handle slipped forward, but hey it's Italian thats to be expected. Chris
| Banned | Re: strange little noise Take it back to your dealer or place of purchase & express your concerns. If your car's new thats what your warranty is for. I have a droning noise when I first open my door to get in but I think that's the fuel pump & is normal( I have the abarth model).
| | #3 | ||
| Re: strange little noise Im sure its probably nothing, more than likely only noticed it cos the stereo was off and the blowers were off. I ve noticed since tho that i can hear 3 little quick beeps when i turn on the ignition. But the check comes up ok, no warning lights. TO be accurate the sound is more like that subtle wooshing noise you get sitting next to a laptop, which is making me think it might be a fan or something... the 3 beeps tho, never heard them before. Its probably just something i havent noticed before. My street is very quiet and i only noticed it tonight when i parked there. I'll give the dealer a call in the morning.
| | #4 | ||
| choose petrol choose revs | Re: strange little noise Could it be the the electric power steering pump priming itself? This is on the right of the steering column; you can see it if you open the fuse panel. Perhaps stick your ear near it, then at least youcan illiminate it.
__________________ Outside the FIAT family for a while but still missing my Coupe 20vT. However, I have the website... www.100hp.co.uk ...now just need the money to buy one (donations gratefully received!) | ||
| | #5 | ||
| Join Date: Jan 2004 Location: Fife, Scotland, United Kingdom.
Thanks: 0 Trader Rating: (0) | Re: strange little noise If its a faint crickly cracily sound from begind the dash when you slow to stop, i'd be interested in this. I have the same thing at the moment! I was wondering if it was 'cause it was really cold outside at the moment!
__________________ 53 plate, Stilo 3-door, Sassy grey, 17" Claw Alloys, Falken Ziex Z512 tyres, 1.2 Active -- 45mpg! | ||
| | #6 | ||
| Re: strange little noise Which Stilo do you have to be exact? On the Abarth when you open the door it activates the pump to prime the selespeed system so there is a whirring noise. Again if the Abarth it could be a fan behind the dash as there is one on the processor of the NAV+ system. If you have climate control it could be the auto actuators on the air distribution flaps moving them with the ignition on. As you turn the wheel it could be the electric motor for the power steering. Or of course the Fairies could be nesting in your dash
| | #7 | |||||
| | #8 | ||
| Re: strange little noise 54 Plate 1.6 Active Sport, The noise (if you can call it that, its almost like the blowers are on slighty). It only happens when the ignition is on MAR or Engine running but at that point its bearly noticable. To clairify this is sitting in the car with manual blowers, all off, stereo off everythign off, with the ignition at MAR. I was reading the manual tonight which mentions Independant Addtional Heater, which mentions that when ignition is at MAR which lets you heat the passenger compartment when the engine is off, window defrosting, heating the engine coolant etc which kicks in below 12oC. Now i am not sure if the active sport has this fitted, but it is bloody freezing outside and something like this would explain this sound quite well. It does sound like a heater or a fan.....anybody?!?! As far as the 3 beeps im pretty sure its just the computers check ok signal. To be totally honest it's not sounding like anything is actually wrong, more just like something i havent heard before and now i have heard it, it will bug me till i know what it is. My dad always said just turn the stereo up..maybe i should heed his advise and stop listening for creaks and beeps. Chris
| | #9 | ||
| Banned | Re: strange little noise Well all I can say m8 is that you've laid out a lot of cash so I think you're entitled to be a bit paranoid eh?
| | #10 | ||
| Re: strange little noise Lets clear this up The static noise: All stilo's make this I have driven or been in. I think it has something to do with what makes the needles move. Just gentley rev it and you'll hear it as the rev counter falls. The whiring noise is again present on all of them i have driven. most likely power steering pump but i think if its made by all of them then its something thats there for a reason. The Quieter the car more things you hear! If you listen carefully, you can hear the fuel pump prime to!
__________________ | |||
| | #11 | ||
| Banned | Re: strange little noise Precisely what I said earlier.
| | #12 | ||
Thanks: 0 Trader Rating: (0) | Re: strange little noise Another once common problem, i've been experiencing it recently, is the electric radiator fan starting when you start the engine, even though the engine is cold. Its down to a poor connection somewhere, letting in moisture or such.
| | #13 | ||
| Grand Stilismo | Re: strange little noise I get the same noise in my dash, fan like noise which stops with a click a few seconds after the keys turned off - Does not bother me though, I just assumed it was a Stilo gadget doing something
__________________ http://photobucket.com/albums/y20/Bo...h_IMG_0646.jpg http://photobucket.com/albums/y20/Bo...h_IMG_0310.jpg http://photobucket.com/albums/y20/Bo...h_IMG_0315.jpg ***************** Broom Yella Fella **************** | ||
| | #14 | |||
It actually sounds like a bad earth (the noise that is). I'd hope it had nothing to do with the needles moving. I always thought it was to do with the LCD screen, seeing as its always lit to some degree! Like if you put an indiglo watch to your ear and press the light button (why you would i have no idea? ) But you hear it hissing.
__________________ 53 plate, Stilo 3-door, Sassy grey, 17" Claw Alloys, Falken Ziex Z512 tyres, 1.2 Active -- 45mpg! | |||
| | #15 | |||||
, shouldnt passive cooling be sufficientanyway the noise is a bit annoying and it keeps going even if you "turn off" the nav. which just puts it in standby
| | dragonsei | Cinquecento / Seicento | 1 | 06-04-2005 20:16 |
| | Geoff | Stilo | 7 | 25-02-2005 10:37 |
| | El Greeno | Uno | 18 | 23-02-2005 10:47 |
| Brava 1.6 16V with a strange noise | Arimathéia | Other Fiats | 1 | 29-11-2004 02:07 |
| | Bushboy | Cinquecento / Seicento | 9 | 03-06-2004 21:55 |
