| 147,Boxster S,GP Multijet | My 1.6 NIGHTMARE!¬ I got my 1.6 back yesterday from the dealer here in Belfast after having it in to correct the 'airbag failiure'. They replaced the sensor under the seat. This morning it happened again. One beep, then nothing rest of day. Tonight driving along the motorway the car started jumping and struggling as if it was running on 3 cylinders. 'Engine fault' was reported. I pulled over and turned off then on, it was shaking violently. Rung AA who were out in 15mins (nice) and the mechanic reported that injector number 4 has died on the car as reported by the ECU in his wee notebook thingy he attached to the engine. The car has been towed to Fiat where I will join it in the morning with the AA diagnosis letter and me very angry as to why my car is falling apart one day after they 'repaired' it. The AA nicely arranged and dropped me off to my waiting courtesy car which Fiat are paying for for 48hrs. What is it - a new Golf! What a couple of days!
__________________ Paul M | ||
| All Hail the Woodsman | Re: My 1.6 NIGHTMARE!¬ I took my car in for a routine service a couple of years back and then couldn't get the thing started, there I am sitting in the dealers carpark and can't leave after handing over a couple of hundred quid to have my car made good. Doh! They came out, took the car round to the workshop and told me the battery had gone dead and too their credit handed me the keys for an Alfa 147 and said come back tomorrow. Came back and its been fine since. Its just one of those things, it probably would have happened on the golf if you'd have had that.
| | #3 | ||
| 5vp3r m0d | Re: My 1.6 NIGHTMARE!¬ Aargh, another coil pack failure.... I must collate the number of times this has happened; becoming way too frequent now.
__________________ Electroclash Panda 100HP ![]() Red brake calipers - done / Red highlights on engine cover - done Red GSR kit - done / Red badges - done / Cobra springs - done ![]() ![]() | ||
| | #4 | ||
| Moderator | Re: My 1.6 NIGHTMARE!¬ Oh dear Paul. You should have kept the Bravo!
| | #5 | ||
| Italian Stallion | the coil packs on modern FIATs are notoriously unreliable, here's a tip however, when you replace one, make sure it's an original, I replaced mine on the Brava with Lucas parts, it blew four of them in three months. I then put an original on and it never broke again. The Lucas ones cost £38, the FIAT one made by Magneti Marelli I believe cost £90 from the dealer. Remember this information in future!
| | #6 | ||
| Join Date: Jan 2004 Location: Fife, Scotland, United Kingdom.
Thanks: 0 Trader Rating: (0) | Re: Arghhhhhhhhhh................................. I asked if someone would collate this weeks ago! ![]() And on which models. By my rought estimate there has been more 1.6 owners commenting. Followed by Abarth owners, then the 1.2 owners. Just curious if its an engine design thing or if it is actually the coil packs? Are they the same between models etc?
__________________ 53 plate, Stilo 3-door, Sassy grey, 17" Claw Alloys, Falken Ziex Z512 tyres, 1.2 Active -- 45mpg! | ||
| | #7 | ||
| Re: My 1.6 NIGHTMARE!¬ i had my first one go on my abarth at 65,000 miles, I ordered a new coil from priory and a lucas one came in a fiat/alfa box. The original was a bosch. If they are likely to keep going I may buy a couple and keep them in the car, a doddle to change. I believe the bosch PN is Type PS 0 221 504 460 14v
| | #8 | |||
| 5vp3r m0d | Re: Arghhhhhhhhhh.................................
Just had way too much on recently - but if you are offering? May be worth a rep point
__________________ Electroclash Panda 100HP ![]() Red brake calipers - done / Red highlights on engine cover - done Red GSR kit - done / Red badges - done / Cobra springs - done ![]() ![]() | |||
| | #9 | ||
| 147,Boxster S,GP Multijet | Re: My 1.6 NIGHTMARE!¬ Right Fiat are just off the phone: Firstly with regards to the continuing airbag problem - they are replacing the seat base unit under the passenger side. They say this will work. With regards to the injector: MENTAL! Not one, but injector 1, 2 and 3 are all dead. They are replacing all 4 as they fear 2 weeks down the line having to strip the engine for the remaining one which could still hit the fan!!! They have no parts unfortunately and due to easter will not have them until next wednesday and its unlikely I can collect my Stilo until next Thursday. They have supplied me with a Pug 206 until my car is fixed. A 1.4LX! hurrah! The Golf from the AA, which is horrible, is going back tonight.
| | #10 | ||
Thanks: 0 Trader Rating: (0) | Re: My 1.6 NIGHTMARE!¬ you'll probably find the 1.4LX 206 is quicker than your Stilo 1.6. Plus you can spank around in it like you stole it! ![]() I would do the research, but err, what do you do? Go through all the posts? I'll have a tinker later!
| | #11 | ||
Thanks: 0 Trader Rating: (0) | Re: My 1.6 NIGHTMARE!¬ Well did some checking of coil pack failures on here! After whittling down all the posts by Stu mentioning his failed Coil pack, which was MOST of the posts mentioning coil pack failures. Here are my findings. 1.2 - 1 unique reported failure. 1.6 - 3 unique reported failures. 1.8 - 0 reported failures. 2.5 - 1 unique reported failure. These are all the unique users reporting coil pack failures on Stilo's only. How do you find out how many rep points you have?
| | #12 | ||
| Grumpy Forum Moderator | Re: My 1.6 NIGHTMARE!¬ Stiloboy.........coils packs are uique to the 1.6 model,the others are on most models interchangable & with other models but 1.6 engine stilo is unique. Paulmacs,I really hope it gets sorted right & quickly,to many injectors are getting fitted with fault reappearing when its the coil thats at fault even though codes are for injectors. Seems strange all the injectors are showing as faulty thought there is a multiplug that can give trouble that feeds the injectors,just a thought?
| | #13 | ||
| 5vp3r m0d | Re: My 1.6 NIGHTMARE!¬ Nice one Stiloboy - I will have to do some checking & marking later ![]() For rep points, click on User CP - it should give you your score, remembering that you started with 4 points.
| | #14 | ||
Thanks: 0 Trader Rating: (0) | Re: My 1.6 NIGHTMARE!¬ I checked only on the words "coil pack" So if i get time i check on posts for just coil, and injectors and add the results of that to my current results. That might be more realistic. I checked all posts with coil pack, and only marked it if the person commenting on their problems actually posted the result from getting the car fixed, and if this was the coil pack problem. Such as CMC, a regular poster who mentioned his car felt like it was running on 3 cylinders, then his wife drove it and it was fine. So i discounted him etc 'cos he never said the garage changed the coil pack.
| | #15 | ||
Thanks: 0 Trader Rating: (0) | Re: My 1.6 NIGHTMARE!¬ oh whoopee doo, i've got 1 point! over the standard 4! God, i post so much useful stuff on here! And not nearly as much drivvel as TC!
| | lyricalmagician | Marea | 8 | 01-03-2005 18:06 |
| Palio 1.6 workshop Manual | roshan | Lets Talk FIAT | 2 | 30-08-2004 02:28 |
| | Rabid Gerbil | Bravo / Brava | 0 | 03-01-2004 18:01 |
| | LMarr | Bravo / Brava | 1 | 20-09-2003 23:00 |
