The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 06-03-2005   #1
Trader Rating: (0)
Air bag despair
3 dr dynamic in Broom yellow...........with smiley air freshner..in yellow of course.
I've had my stilo for 3 months and apart from a few minor probs like a duff engine,that was replaced, we have had a good relationship.
6 weeks before the warranty ends both air bag lights have burst into life.
Last night the drivers air bag light came on and the display said 'stop engine'. From reading previous threads I remembered the wiring is a tad suspect, so afumbling I went and the light and warning display went out after getting all touchy feely with the spaghetti under the seat nearly instantly. HURRAH!
Any of you lot fellow Stilo Edward Cases out there know which wire or con block is favourite to give such a fault?
But wait! Like an offer from DFS sofas, there's more.The anti-kiddy rear facing air bag immobliser on the passenger seat also comes on and off at will, approx. every 30 mins for about 5 secs. It doesn't matter if there's somebody in the seat or not. (If I had a choice would prefer a good blonde, any body know any?)
Again, I think this is similar to previous threads any thoughts on cause, rectification under waranty in the third year?
Stanley knife's and sellotape at the ready to start cutting all those pretty coloured wires.
Ash
apsbasketcase is offline
Old 06-03-2005   #2
Grumpy Forum Moderator
T14086's Avatar
Trader Rating: (0)
T14086 has donated! United Kingdom
Re: Air bag despair
You want to cut airbag wires I take it you were kidding
With ignition switched off ust disconnect & reconnect the 2/3 multiplugs under the seat thats normally enough,if you have any a cable tie is good to wrap around the plug to keep the connection tight.
Might need a sensor mat for the pass seat though & common fault,its a easy job to do.
T14086 is offline
Old 06-03-2005   #3
5vp3r m0d
Stu DemonD's Avatar
Trader Rating: (1)
Stu DemonD has donated! United Kingdom
Re: Air bag despair
I have just had my sensor mat replaced, and still the airbag lights come on when a passenger sits on it.
Going back in again to be rechecked [along with my brake light stuck on AGAIN, and a new n/s light unit], but I may do what T14086 says and see if that helps
Electroclash Panda 100HP
Red brake calipers - done / Red highlights on engine cover - done
Red GSR kit - done / Red badges - done / Cobra springs - done
Stu DemonD is offline
Old 06-03-2005   #4
Trader Rating: (0)
Re: Air bag despair
T14086,
I tried disconnecting the 2 blocks, counted to 5 secs, reconnected the blocks, turned the ignition on and................DAMN! 'airbag failure'. OK I give up, tele/con with the dealer tomorrow.
Stuart,
Ta for the sensor mat info I'll cross swords with the dealer on this as well.
Tally Ho!
Old 07-03-2005   #5
T14086's Avatar
Trader Rating: (0)
Re: Air bag despair
You need to clear the codes (you have probably sorted the connection problem) but fault will still be logged.Ask dealer to delete it (for free,1 minute job) & check seat base mat aswell,although you can normally tell these are knackered if you feel the seat you feel sharp lumps where the circuit mat sensors have broken.
By the way when I ment seat base is a easy job I ment for the dealer,I wouldn't recommend anyone stripping seat down especially if it has side airbags,talkin from experience here!
T14086 is offline
(T) Battery Drain...air bag nuttershome Stilo 7 01-04-2005 13:25
(G) Airbox on mk2 45 chrisunoman Uno 13 23-12-2004 01:15
(T) air box mod revisited jbackg Marea 1 18-08-2004 01:33
(T) Air bag light bobsinger Marea 5 02-05-2004 02:44
(T) fuse for air bag light wongy008 Punto 6 21-01-2004 04:56
