| Re: Audio Stalk Sony to Stilo Hi Did you ever find out where to get one? Thanks
| | #3 | ||
| Re: Audio Stalk Sony to Stilo I've got one, you can buy them in any car radio outlet for about £30. Easily fitted, pull your radio out and remove the lower half of the steering wheel plastics (the bit that fits over the ignition switch. Find some stiff wire (easier to control where it goes) and, from the back and on the right of where the radio sits, feed the wire through the hole until you can see enough of it to pull through. With insulation tape join the wire to the jack on the stalk and pull it back through. Connect jack to appropriate position in back of radio. drill hole in lower removed steering plastic, screw stalk base onto said, fit stalk, refit plastic, refit radio, tidy wiring, all done.
| | #4 | ||
| Re: Audio Stalk Sony to Stilo Only suitable for Sony
| | #5 | ||
| Re: Audio Stalk Sony to Stilo Thanks. Might get someone else to fit it though...
| | #6 | ||
| Re: Audio Stalk Sony to Stilo It's not a difficult job and would take an hour max if you're really be careful
| | KubaM | Stilo | 2 | 06-02-2005 01:27 |
| Stilo Audio | Mike1a1 | I.C.E | 1 | 12-09-2004 20:59 |
| FREE Club Stilo Stickers! | twincamms | Leisure Lounge | 0 | 03-05-2004 20:19 |
| Club Stilo Stickers! | twincamms | Lets Talk FIAT | 0 | 03-05-2004 20:04 |
| | big-al | Stilo | 5 | 04-11-2003 01:53 |
