The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 25-10-2004   #1
pc99's Avatar
Trader Rating: (0)
Climate Control - hot air on passenger side only
Has anybody else experienced this problem.
The climate control on my car has got 'stuck' twice now. When this happens, the passenger side vents blow out hot air, regardless of the temperature setting. Fiddling with all the controls has no effect, although the drivers side adjusts with the settings.
After switching off the ignition and coming back later, all seems okay again.
I assume that what is happening is that the passenger side vents are sticking in one position.
Just wondering if I'm the first.
Graham
3DR Stilo Abarth Jet Blue with Skywindow/Leather/Cold Climate Pack. Dension DH100ix HD MP3 Player.
pc99 is offline
Old 26-10-2004   #2
Trader Rating: (0)
re: Climate Control - hot air on passenger side only
I've had the same, I booked the car in to the garage to have it looked at but 2 days before it was due in it sorted itself out, typical. I've not had this problem since, this must have been over 6 months ago now
Stilo Abarth,
Mike1a1 is offline
Old 27-10-2004   #3
pc99's Avatar
Trader Rating: (0)
It's nice to know I'm not alone.
I guess I'll keep an eye on it and if it keeps doing it, I'll have to book it in.
Graham
pc99 is offline
Old 25-11-2004   #4
Trader Rating: (0)
It will be the air mixer paddles messing up and causing the problem. Mine has exactly the same issue, and eventually Techinical came down and diagnosed that a motor needed replacing. Collecting the car on Friday, so fingers crossed...
Regards,
James Mayl
Slinky Wizard is offline
Old 30-11-2004   #5
pc99's Avatar
Trader Rating: (0)
Cheers for the info.
I'll ask the dealer to take a look next time I book the car in. I have a couple of other niggles to sort out.
Graham
pc99 is offline
Old 10-12-2004   #6
PMasia's Avatar
Trader Rating: (0)
My Stilo Abarth has done 28000 and my climate system has developed this fault. It's booked tommorow, I will post my results.
Stilo Abarth, Broom Yellow, Sill Kick Plates, 18" OZ Titan alloys, Eibach Sport line spings, lowered 35 mil, 5 stack cd changer, Alarm, Nav software version = 9.8
PMasia is offline
Old 15-12-2004   #7
pc99's Avatar
Trader Rating: (0)
I've actually booked mine in to be looked at on Friday, along with a couple of other problems.
Graham
pc99 is offline
Old 17-02-2005   #8
Trader Rating: (0)
timr69 has donated! United Kingdom
Climate control - cold air only on drivers side?
I've got the dual zone climate on my MW.
This morning coming to work when I switched the heating on the drivers side just blew out cold air but the passengers side was blowing out whatever temp I selected.
I finally fixed it by stopping, switching off then starting up again and pressing loads of buttons and adjusting the temp.
It's not the first time this has happened (maybe twice before) but it's annoying.
Has anyone else had this?
2003 Fiat Stilo Multiwagon JTD Dynamic
1999 Fiat Coupé 20 valve turbo
1992 Mitsubishi Shogun TD 7 Seater
timr69 is offline
Old 28-06-2005   #9
84jr0's Avatar
Trader Rating: (0)
Sweden
re: Climate control - cold air only on drivers side?
I have same problem now but mine is blowing warm air at drivers side and what ever I select on passengers. Observe that my drivers side is to the left...
Fiat checked my car but they could not find any fault, what they did is to calibrate my ACC I don't know exactly what they have done...
So, anybody else with same problems?
84jr0 is offline
Old 29-06-2005   #10
pc99's Avatar
Trader Rating: (0)
I had this problem intermittantly.
I've just had it fixed - before the warranty expired.
The fault item was an actuator which controls the position of the paddles which direct airflow to the various outlets.
It's taken several months and several visits for my dealer to even diagnose the problem, and then several attempts to actually order the right part.
Graham
pc99 is offline
Old 29-06-2005   #11
84jr0's Avatar
Trader Rating: (0)
Sweden
Did you have the problem all the time or just sometimes like 2 times in 2 months? It's kind of hard for Fiat to find the fault if it works like it should when you show them your car!
84jr0 is offline
Old 29-06-2005   #12
Trader Rating: (0)
My dealer diagnosed the problem as the 'mixture flap' which wasn't working properly all the time.
They ordered a new one form Fiat who 'sent them something completely different' but with the correct part number.
The car was in last week so they could take it to pieces to look at the mixture flap and get the correct part number off it
They'll give me a phone when the bit comes in. I'm still waiting......
timr69 is offline
Old 30-06-2005   #13
pc99's Avatar
Trader Rating: (0)
84jro,
The problem with one side or the other blowing hot when it should've been cold etc, only happened once a week or so.
However it started to deteriorate and if you manually switched vents on and off, the airflow didn't always change.
Ie the unit had a light saying air should only be coming out of the footwell vents but it's blasting out of the windscreen ones as well.
timr69,
I had the exact same problem. They ordered a part, waited ages, ripped the car apart and found it was the wrong part. Then tried to charge me, which I politely refused.
They finally got the correct part and fitted it last week.
Touch wood it seems to be behaving itself so far.
Graham
pc99 is offline
Old 06-07-2005   #14
pc99's Avatar
Trader Rating: (0)
Aaarrrgghhh!!!
This morning I got hot air out of the passenger side vents even when the controls were set to 'LO'.
So the new actuator doesn't seem to have fixed the problem.
And now my warranty has expired.
I repeat. Aaarrrgghhh!!!
Graham
pc99 is offline
Old 06-07-2005   #15
5vp3r m0d
Stu DemonD's Avatar
Trader Rating: (1)
Stu DemonD has donated! United Kingdom
Surely if the problem was reported under warranty, and their 'fix' was wrong, you should still be covered?
Go back to dealership - if they get shirty, phone up FIAT Uk and/or Trading Standards.
Electroclash Panda 100HP
Red brake calipers - done / Red highlights on engine cover - done
Red GSR kit - done / Red badges - done / Cobra springs - done
Stu DemonD is offline
(T) climate control only blowing cold?? wsty Stilo 2 11-10-2008 12:37
Climate control/air con clair80 Panda (New) 11 11-07-2008 13:00
Air con or climate control? Rustbucket Barchetta 5 01-04-2008 21:51
(G) Help with Air Con/Climate Control Gusfiat 500 5 31-03-2008 16:49
