| Just some thoughts... When I went down to Colchester at the weekend I had two passengers plus the Baby and a very full heavy boot. I usually keep the tyre pressure at 2.1 Bar (17inch wheels 215/45 profile tyres) which the handbook says is the pressure for light to medium load. Because of the extra weight I increased the pressure - again according to the handbook - to the indicated 2.3 Bar. On the journey everything was fine. My point is since increasing the pressure both under the heavy load and today driving around with just me and Amanda in the car; the road holding and handling seems to have improved. I went down some twisty roads at a fair pace and on corners where I'd previously get a bit of understeer there was none...Is this real or just my imagination? It appeared to be so improved I'm loath to decrease to 2.1 Bar now. Also, since the tyres were scrubbing less I expect tyre wear would be less too. Is incorrect tyre pressure a factor in all these cases of premature tyre wear on Stilos? I can't remember tyre pressures being mentioned too much in these threads? As I say I check my tyre pressure at least every fortnight using a digital electric inflator and double checked with another digital gauge always at cold temp. Have people that suffered premature tyre wear checked pressures often? Perhaps using the upper 2.3Bar limit would help? What do you guys think? thoughts comments please - sorry for another longish post I couldn't think how to condense it!
__________________ Stilo Abarth manual/Techno Grey/Grey-Cream leather/17inch alloys/BMC Carbon Dynamic Airbox/Angel Tuning Re-map/Road Angel Navigator Citroen C4 2.0 HDI VTR+ Red/17 inch alloys/& lots of toys! (my work car), which is why its not a Fiat!! | |||
| Join Date: Jan 2004 Location: Fife, Scotland, United Kingdom.
Thanks: 0 Trader Rating: (0) | Re: Tyre Pressure Usually higher pressure will cause less grip, but obviously less drag. I used to run my Escort TDi at the upper rating, i was usually the only person in the car, i drove mainly motorway so the slight loss in grip wasn't noted but the slight improvement in economy was worth it. However higher pressure means less squidge in the tyres, and possibly more drumming, so more road noise.
__________________ 53 plate, Stilo 3-door, Sassy grey, 17" Claw Alloys, Falken Ziex Z512 tyres, 1.2 Active -- 45mpg! | ||
| | #3 | |||
__________________ Stilo Abarth manual/Techno Grey/Grey-Cream leather/17inch alloys/BMC Carbon Dynamic Airbox/Angel Tuning Re-map/Road Angel Navigator Citroen C4 2.0 HDI VTR+ Red/17 inch alloys/& lots of toys! (my work car), which is why its not a Fiat!! | ||||
| | #4 | |||
| Re: Tyre Pressure
Paul BTW - the pressures in my tyres were around 2.1 bar, and I had to increase them to 2.3 myself!
__________________ Stilo Abarth Selespeed 3dr, Broom Yellow (Nov '03) Ulysse 2.0 16V EL, Forest Green Metallic (Oct '01) Last edited by pjp; 15-02-2005 at 09:24. | ||||
| | #5 | ||
| 5vp3r m0d | Re: Tyre Pressure Anyone know the PSI conversion? I got a digital meter, and it doesn't do bar.
__________________ Electroclash Panda 100HP ![]() Red brake calipers - done / Red highlights on engine cover - done Red GSR kit - done / Red badges - done / Cobra springs - done ![]() ![]() | ||
| | #6 | ||
| Re: Tyre Pressure yeah, 1 bar is equal to 14.50377399 pounds/sq inch, so that would make 2.3 bar 33.35868019 psi.
__________________ 2006, 1.2 Grande Punto Active, Orange Met. 2004, 1.9 JTD Dynamic, Chrome Grey with 17's, Full Leather Pack, Skirts etc. The rest is a secret | |||
| | #7 | |||
Crap!! Your right!! You'd think after a decent education and four years of Uni I'd of learnt how to read figures off a page correctly (even more worrying given the job I do)!! I just went out to check the manual 2.3 it is, even for light-medium load. So, for almost a year now, I've been going around under inflated..........oops. Still, like I say, the car does feel better now! :-) Thanks for pointing it out. :-)
| | #8 | ||
| Re: Tyre Pressure Ive managed to misplace my manula and was wondering what are the proper air pressure settings for standard (factory fitted) fiat stilo wheels?
| | #9 | |||
| Re: Tyre Pressure
__________________ Stilo Abarth Selespeed 3dr, Broom Yellow (Nov '03) Ulysse 2.0 16V EL, Forest Green Metallic (Oct '01) | ||||
| | #10 | ||
| 5vp3r m0d | Re: Tyre Pressure If no-one does it by tonight, I will scan in the relevant page from the manual and host it on here
| | #12 | |||||
| Banned | Re: Tyre Pressure
Seems fine, mind you I only have the 16" wheels.
| | #13 | ||
| Ferrari Fanatic | Re: Tyre Pressure I run mine at 31.5 psi all round (205/55/16). I check them every other week and the wear is even.
__________________ Simon Alfa Romeo 159 2.2 Ti in Grigo Stromboli & 3.2V6 GT in Rosso (but still a Fiat fan | ||
| | #15 | ||
| Re: Tyre Pressure I've an Abarth on 215/45/17 alloys. Rounding up it should be 34 PSI from the bar conversion, I go one up than that to 35 all round. Both under and over inflation is dangerous, but I think +/- 5% should be ok. What I would do is get a proper calibrated hand held tyre pressure gauge as those in garages, supermarkets etc can be woefully inaccurate. A blow out at motorway speeds due to under or over inflation can be "fun" if not fatal! Key here, as most people seem to do, are regular checks. Who changes their tyre pressures when they go on holiday 4 up with loads of luggage? (bet hardly anyone).
| | 4paws | Uno | 2 | 04-01-2005 17:36 |
| | MeAcHeM45 | Uno | 3 | 16-10-2004 18:31 |
| tyre pressure | baslaityer | Ulysse | 11 | 10-12-2003 19:21 |
| | baz83 | Cinquecento / Seicento | 3 | 05-05-2003 03:16 |
| | keanie | Punto | 3 | 20-04-2003 23:18 |
