| air con? Stilo 1.6 dynamic 3 door........16" alloys...........need 17" Any of you learned people out there know how to check the air con is working. It's currently about -1 deg C outside so turning it on has no affect and my warranty is up in a few months. I've tried turning the heating on to max and turning on the air con on, no noticable temperature change. Thanks to all Dawn and Ash
| Was VXR enough :( | Re: air con? Air con only chills air doesnt it? The heat comes from the engine and that has to warm up first....... Edit- Just re-read and I think ive got the wrong end of the stick- sorry
__________________ Fiat Punto Active Skoda Fabia vRS Vauxhall Astra VXR SEAT Ibiza 20VT FR Renault Clio 182 & Honda CB600FA Hornet Last edited by wolfracepunto; 14-02-2005 at 00:30. | ||
| | #3 | |||
| Paparrazi | Re: air con?
Oh and stating the obvious, but don't run the engine in a closed space with you in it....
__________________ -- Neil Barker Techno Grey 3dr Abarth Selespeed now replaced by a 2008 Toyota Avensis TR 2.2TD Sadly, I am unable to recommend Sunwin Fiat Derby due to my experiences there | |||
| | #4 | ||
| Re: air con? Does anybody know where the sight glass is to check if the refridgerant is flowing? Ta Ash
| | #5 | |||
| Peek a boo! | Re: air con?
__________________ -------------------------------------------------------- | |||
| | #6 | ||
| 5vp3r m0d | Re: air con? Good idea about checking it before warranty up, although if no gas left in it, I doubt it would get changed under warranty. As for running it, it is best to at least switch it on occassionally over the winter months, otherwise the seals go. Luckily I have climate control, so all this is controlled automatically
__________________ Electroclash Panda 100HP ![]() Red brake calipers - done / Red highlights on engine cover - done Red GSR kit - done / Red badges - done / Cobra springs - done ![]() ![]() | ||
| | #7 | ||
| Re: air con? Hi Ash , its Chris N. You and your missus get the car all steamy inside , then turn on the AC, regardless to the outside temp i'll still de-humidify the air, if the screen de-mists pretty much instantly the ac's ok. PS mines going in on the 5th of march to have the "tappit" noise looked at, According to JCS fiat know about the faulty engines (worrying) and theres some tests they can do to confirm, watch this space. :
| | #8 | |||
| Re: air con?
__________________ Stilo Abarth Selespeed 3dr, Broom Yellow (Nov '03) Ulysse 2.0 16V EL, Forest Green Metallic (Oct '01) | ||||
| | #9 | ||
| Re: air con? Yes i agree on climate control that is true because its an auto matic system, however us low lifes only have an on/off button it works or it doesn't, I use the air con all the time to de-mist the screen rapidly when i've been walking the dog in the rain regardless of the outside temp. Also good for mixing de-humidified air in and keeping the screen clear when you have a car full. PS nice wheels - just like mine.
| | #10 | |||
| Re: air con?
| | #11 | |||
| | #12 | ||
| Re: air con? Well, since we had a warmer day today, I thought I would turn on my A/C after my car had been sitting in the sun all day. It did not work. The light came on and I could hear something click under the dash, but the compressor did not click on. I presume that there is a leak in the system and that there is no refridgerant. Refridgerant should not leak, and should never need topping up, unless there is a leak in the system, as far as I know. My 52 only has 8,000 miles on it. It was brand new when I bought it last May (cheap!), and had apparently been sitting in a field for almost two years, along with a whole bunch of other Stilos, so I would hope that this would be fixed under warranty? I did check the compressor fuse and it was fine.
__________________ 52 Stilo 1.6 Active AirCon 5 door. Metallic Navy Blue | |||
| | #13 | ||
| Re: air con? my air con packed in on my 02 1.6 dynamic. turns out a pipe at the front ruptured and it wasn't covered under the 3rd year warranty - £220 to fix. Get it in while you are still in year 2 of the warranty as seeminlgy this is not uncommon. cmc
__________________ 1.6 Dynmamic 5 door now gone ![]() Can't bring myself to leave the forum though ![]() Mk1 Seat Leon Cupra 1.8T & Mk2 Seat Leon 1.6 Stylance | |||
| | #14 | |||
| Re: air con?
__________________ 52 Stilo 1.6 Active AirCon 5 door. Metallic Navy Blue | ||||
| | #15 | ||
| Re: air con? stilos are infamous for air-con not working after system hasnt been used for a few weeks, most cases it just needs a squirt of gas into the car to get things working again, apparently the trinary switch sticks if system isnt used for a while and a squirt of pressure into the system sorts it out. trouble is you wont find a garage that will give you a squirt of gas, they will tell you it needs a full evac and re-charge, which to be honest is the best thing you can do anyway to get 100% efficiency outta it. summer is coming, and the stilos are already pouring through the door for air-con re-charges. oh and if any1 decides to get a re-gas, ask if they can also clean the system, this is where a chemical (gas) is added in through the heater re-circ flap, it kills all those nasty bugs and smells that have gotton onto the evaporator inside the heater box and all the internal piping from the heater box to your vents, its added cost but trust me its worth every penny, smells crisp n clear after and keeps the system healthy from bugs.
__________________ my identity shall remain a secret, so i dont lose my job! | |||
| | chrisunoman | Uno | 13 | 23-12-2004 01:15 |
| | thatsean | Stilo | 2 | 10-09-2004 14:39 |
| | kangarolf | Bravo / Brava | 1 | 08-09-2004 13:19 |
| | jbackg | Marea | 1 | 18-08-2004 01:33 |
| | buckster | Stilo | 9 | 11-08-2003 15:53 |
