The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 21-01-2005   #1
StiloJoe's Avatar
Trader Rating: (1)
Engine fault/Security fault
Came hoem from work and was all fine got back in later and started it got a warning as above
Thought right ok turned key of and the engine runs still !!!!! everything else is off but keeps running i can lock doors everything only way i can turn it off was to drop it in 6th and lift clutch to stall it
Bloody thing any ideas?
StiloJoe is offline
Old 22-01-2005   #2
Trader Rating: (0)
Re: Engine fault/Security fault
Scary, you'd think when you take the key out the ignition the imolibiser if anything would kill the engine! Afterall its supposed to stop the car being able to be started! It should cut battery! Sounds well worrying!
53 plate, Stilo 3-door, Sassy grey, 17" Claw Alloys, Falken Ziex Z512 tyres, 1.2 Active -- 45mpg!
StiloBoy is offline
Old 22-01-2005   #3
StiloJoe's Avatar
Trader Rating: (1)
I have taken it into the garage where i had it from today and as far as they know its the fuse box which they have ordered. Hopefully this will sort it as they have gave me a 54 plate 1.2 punto which feels down hill from the stilo
StiloJoe is offline
Old 22-01-2005   #4
Cango's Avatar
Trader Rating: (0)
Wow man that was scary.. Hope its nothing important.. I also have a problem, although i dont know if it is a problem..When i press the clutch it some times holds the engine still at 2000rpm for 7-8seconds.. Does anyone know what is the problem or is that a problem?
I NEED A TURBOCHARGER!!!
Cango is offline
Old 30-01-2005   #5
StiloJoe's Avatar
Trader Rating: (1)
Now been in a week and they STILL not even looked at it
Starting to make me feel like they can keep it P*ssin me right off
StiloJoe is offline
Old 31-01-2005   #6
Trader Rating: (0)
Well obviously the car isn't safe to drive, in the event of any kind of incident, or even just going for petrol, you can't turn the engine off without having to forcefully stall the car.
Imagine you emergency stop to avoid hitting a kid, then stalling the car and jumping right over them just to stop the engine!
I'd go mental at the garage, citing its un-safeness for driving and get them told. I wouldn't be surprised if its really easy to fix. Try turning up at the garage with the car just before 8am and asking if they can squeeze you in and check it on the diagnostic equipment. It will only take them 5 minutes, and they might even be able to fix it there and then.
StiloBoy is offline
Old 06-02-2005   #7
StiloJoe's Avatar
Trader Rating: (1)
*update*
Car went in on 22nd Jan
Still no luck only thing they told be is that needs a new ECU cos they checked it
Prob is that they cant get 1 even from Italy so at the mo its sat in the forcourt look pitiful for itself and me running round in a bog standard MK3 punto which feels rubbish (No offence to anyone who has 1 but this does feel crap)
I have a full ICE system ready to drop in and cant do anything till they get it sorted so im kinda pissed
StiloJoe is offline
Old 06-02-2005   #8
Grim_Evil's Avatar
Trader Rating: (0)
thats not nice news, hope you get it sorted soon
Grim_Evil is offline
Old 11-02-2005   #9
StiloJoe's Avatar
Trader Rating: (1)
*UPDATE*
Finally today got it back running well smooth
Had new ecu and a new peice of wiring but all good now after 3 weeks without it
StiloJoe is offline
(T) Engine Fault!! Borromir Stilo 15 16-01-2008 00:16
(T) Engine Fault - any ideas? StiloBoy Stilo 24 17-01-2005 23:41
(T) engine swaps fixitagaintomorrow Cinquecento / Seicento 0 31-12-2004 01:17
(T) Stilo Engine Fault Paul Mc Stilo 3 01-12-2004 18:53
(T) Engine Fault? msmbus Stilo 3 29-02-2004 23:01
