| Rain sensor What does everyone think about the rain sensor on the stilo? I think mines is either faulty or are they just crap? It takes ages to clear the screen and only does it after there is an awful lot of water on it. It's odd as I keep needing to turn the switch off and then back to kick start it again. For example, the rain sensor is supposed to be on. Water builds up on the screen and it doesn't clear so I switch it off then on again and it clears right away, weird. Anyone any thoughts on this? cmc
__________________ 1.6 Dynmamic 5 door now gone ![]() Can't bring myself to leave the forum though ![]() Mk1 Seat Leon Cupra 1.8T & Mk2 Seat Leon 1.6 Stylance | |||
| Re: Rain sensor I can't say I'm particularly impressed with the one on my car either - I thought it would be a turn on and forget thing - I think I fiddle with it more than an ordinary wiper if the truth is known. I previously had a 3 series with manual wipers, but it automatically switched them to intermittent when you slowed down and stopped - IMHO I think that worked better Paul
__________________ Stilo Abarth Selespeed 3dr, Broom Yellow (Nov '03) Ulysse 2.0 16V EL, Forest Green Metallic (Oct '01) | |||
| | #3 | ||
| Join Date: Aug 2003 Location: Fife, Scotland, United Kingdom.
Thanks: 0 Trader Rating: (0) | Re: Rain sensor you do have to reset them every time you start up the car. But otherwise I think they are fine, if anything they are too sensitive for me at times
__________________ Scorg 01 Brava 80SX - Ink Black 02 Stilo Dynamic 1.6 - Sky Blue 03 Punto 60 Active - Silver Blue | ||
| | #4 | ||
| Re: Rain sensor Hi, I had a similar problem with the rain sensor on my Stilo when I first picked it up from the dealer. It would only wipe once the window was completely covered with water. Positively dangerous. They finally tracked it down to the fact that the sensor had delaminated from the glass. Once they arranged for an auto glass company to re-attach it the problem went away. Get them to check how well your sensor is attached to the glass
__________________ Black Alfa 159, Black Alfa 147 | |||
| | #5 | ||
| Re: Rain sensor I think I'll take it in to the dealer for a look then to see if it has become de-laminated. As you say pjp, I fiddle with them non stop as well. cheers cmc
| Flywheel sensor and dowels question | ben743 | Tipo | 0 | 19-12-2004 22:43 |
| | cento_cursed | Cinquecento / Seicento | 6 | 14-11-2004 11:58 |
| RPM & Lambda Sensor (Coupe 16V Turbo) | CYL | Coupe | 1 | 09-11-2004 23:33 |
| | GeX | Cinquecento / Seicento | 3 | 08-09-2004 00:43 |
| | andyblackett | Stilo | 3 | 11-08-2003 19:00 |
