The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 12-11-2004   #1
pc99's Avatar
Trader Rating: (0)
Traction control warning light
I've noticed that the traction control warning light on the dash keeps coming on a lot more than it used to.
It seems to happen on specific stretches of road and is repeatable, however I never really noticed it before.
These stretches of road are straight and reasonaly well surfaced, and it happens in the dry as well as in the wet.
I've also noticed a lack of power when the light is flashing, which is what I would expect, as I assume it cuts the power or applies the brakes.
Does this sound like something is too sensitive? Can it be adjusted.
Has anyone else had a similar problem?
Graham
3DR Stilo Abarth Jet Blue with Skywindow/Leather/Cold Climate Pack. Dension DH100ix HD MP3 Player.
pc99 is offline
Old 12-11-2004   #2
daftcars.com's Avatar
Trader Rating: (0)
Re: Traction control warning light
What are you driving like at the time that it comes on? It's just that I'm suprised it comes on at all. Mine has never come, even when hoofing it. Granted, mines a 1.8, so the Abarth might be different, but I wouldn't expect it to be activated unless under extreme conditions.
daftcars.com is offline
Old 12-11-2004   #3
froggie 666's Avatar
Trader Rating: (0)
Ireland
Check that your brake lights aren't sticking on, mine had to have a new switch on the brake pedal.
Stilo Abarth BLACK !! 02, 3dr.......
froggie 666 is offline
Old 12-11-2004   #4
5vp3r m0d
Stu DemonD's Avatar
Trader Rating: (1)
Stu DemonD has donated! United Kingdom
I do find my TC comes on quite often, lol - but not on long dry roads - tends to be more into corners, roundabouts, and when wet.
Plus I have a 5 door, so the body roll more pronounced.
Electroclash Panda 100HP
Red brake calipers - done / Red highlights on engine cover - done
Red GSR kit - done / Red badges - done / Cobra springs - done
Stu DemonD is offline
Old 12-11-2004   #5
Big Black Stilo's Avatar
Trader Rating: (0)
mine comes on often. only when im booting it off the start to get away quick or wet roundabouts.
It went mental when the car spun off on the motorway!
Big Black Stilo is offline
Old 12-11-2004   #6
pjp
Trader Rating: (0)
The Abarth has ESP which consists of a seperate hydraulic pump that can apply braking automatically to each of the wheels to control wheelspin and/or
correct skids/understeer/oversteer.
This is different to the other stilos that don't have ESP which simply cut engine power to control wheelspin.
Paul
Stilo Abarth Selespeed 3dr, Broom Yellow (Nov '03)
Ulysse 2.0 16V EL, Forest Green Metallic (Oct '01)
pjp is offline
Old 12-11-2004   #7
pjp
Trader Rating: (0)
Now you've started this story you got to finish it. What happened? Did the ESP help?
Paul
pjp is offline
Old 12-11-2004   #8
pc99's Avatar
Trader Rating: (0)
I guess I usually drive it quite hard. But as I said, it's often just accelerating on a perfectly straight piece of road.
And I'm sure it's been happening a lot more recently.
Froggie666, I did have the stuck brake problem a while back, and the switch was replaced. I don't think I've got it again now. But I guess maybe I should talk to the dealer, to see if there's anything they can check.
Graham
pc99 is offline
Old 16-11-2004   #9
Trader Rating: (0)
had the same problem would cut in on a slight bend and loss of power, if you notice feels a little loose on corners.
Answer new steering rack fitted under warrenty! must be a fault of defective component.
02 abarth 2.4 total time in garage 13months 3 days 13000 nightmare miles but when it's okay what a car.
markoha is offline
(T) Punto "Bulbcheck" Amber warning light on dashboard Paul C Punto 24 3 Weeks Ago 11:12
(T) Fuel Injector Warning light karmapolice Punto 4 10-01-2006 01:44
(T) Injector Warning Light / Temp Gauge Probs chuck Bravo / Brava 20 29-10-2004 00:06
(T) Stlo Bulb Failure Warning light Brad Stilo 9 06-04-2004 20:07
(T) warning light Grav Bravo / Brava 3 23-02-2004 14:56
