The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 17-10-2004   #1
Trader Rating: (0)
Possible BIG problem
Hi All,
Managed to get my Air Warning light sorted (loose connection on passanger seat). Now I have a bigger problem. When I turn off the ignition and lock the car, via the remote, the fog lights come on and the rad. cooling fan comes on - only way to stop it is to disconnect the battery (otherwise fan and lights remain on until battery flat).
Has anyone else had this problem or have ideas ???
Fiat Stilo Abarth on a '02' plate
dexys is offline
Old 17-10-2004   #2
Trader Rating: (0)
Re: Possible BIG problem
Sounds pretty catastrophic, what happens when you lock the car with the key in the lock?
53 plate, Stilo 3-door, Sassy grey, 17" Claw Alloys, Falken Ziex Z512 tyres, 1.2 Active -- 45mpg!
StiloBoy is offline
Old 17-10-2004   #3
5vp3r m0d
Stu DemonD's Avatar
Trader Rating: (1)
Stu DemonD has donated! United Kingdom
Dexys, did this problem come about after the garage had fixed the airbag light???
Can't you just take it back to dealer?
Electroclash Panda 100HP
Red brake calipers - done / Red highlights on engine cover - done
Red GSR kit - done / Red badges - done / Cobra springs - done
Stu DemonD is offline
Old 17-10-2004   #4
Trader Rating: (0)
Problem occured after giving the car a jetwash, I was able to, fix the air bag problem myself after readi8ng some of the previous posting on this sitelooked at my 'orange' connector under the seat to find it was almost completely unconnect.
Problem appears to occur once the ignition is switched off and the drivers door is close approx. 30secs delay then fan and fog lights come on even without locking the car, manually or via remote locking......
Ideas most welcome......I'm starting to believe this car is not fit for the purpose for which it was designed, which based on my minimal legal experience is a failure under the Sales Of Goods Act.....
dexys is offline
Old 22-10-2004   #5
Glutton for Punishment
Rich's Avatar
Trader Rating: (1)
Rich has donated! United Kingdom
Jetwashing cars never seems like a good idea! It seems that water could have got into the main junction box on top of the battery; I cleaned my engine once and the full-beam headlamps were flashing on and off by themselves, and I got an Engine Fault warning the next morning.
If you jetwashed inside the engine then FIAT might get picky. I was told of a mod. to the wiring loom at the front as the cooling fan can stick on if a wiring connector got wet; my brothers Abarth had that problem. As for the foglights, I expect its the same problem as I had, although it had gone away the next morning.
07 Bravo TJet Sport, Maranello Red
Factory Options: Dual Zone Climate, 18" Alloys
Retrofitted: Armrest with conditioned foodbox, Stainless Kick Plates
Sister's: 06 Grande Punto 1.4 Dynamic, Crossover Black, Red Badge Conversion
Rich is offline
Old 23-10-2004   #6
Trader Rating: (0)
Yeah Jetwash is find if you only use it directly under the car, but careful under the front. I'd pop the bonnet and anything that looked like a connector give it quick dousing with WD40, leave the bonnet up for 20 mins in the sun and i'm sure any moisture will be cleared, also check all connections are secure.
StiloBoy is offline
Old 23-10-2004   #7
Koa
Free dentistry available
Koa's Avatar
Trader Rating: (4)
Koa has donated! United Kingdom
I had similar problem with my focus... turned out to be water inside the electrics after a wash... but it took a week to dry out propper
Koa is offline
Old 25-10-2004   #8
Trader Rating: (0)
I think that must have been the problem (hopefully) the problem appears to have disappeared - fingers crossed !!!
dexys is offline
(T) Big problem with my Brava 96' Garibaldi Bravo / Brava 5 04-07-2004 23:51
(T) Wheel big problem NIbbo Cinquecento / Seicento 8 04-07-2004 19:36
(T) Pretty big problem!! MilesBetterThanYou Cinquecento / Seicento 5 04-05-2004 20:06
(T) New big problem!! goldflame Cinquecento / Seicento 10 27-04-2004 13:59
(T) A pretty BIG problem (Speedo Cable) Little Red Devil Cinquecento / Seicento 6 08-03-2004 04:12
