The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 09-10-2004   #1
Grim_Evil's Avatar
Trader Rating: (0)
Question radio removal
How do I remove the radio from my stilo??
So I can fit a new one???
Grim_Evil is offline
Old 09-10-2004   #2
5vp3r m0d
Stu DemonD's Avatar
Trader Rating: (1)
Stu DemonD has donated! United Kingdom
Re: radio removal
What radio is it?
You either need a special radio removal instrument, or alternatively a couple of long thin screwdrivers to put down the holes, two on each side, to release the catches before easing it out.
Electroclash Panda 100HP
Red brake calipers - done / Red highlights on engine cover - done
Red GSR kit - done / Red badges - done / Cobra springs - done
Stu DemonD is offline
Old 09-10-2004   #3
Grim_Evil's Avatar
Trader Rating: (0)
Re: radio removal
thanks will have ago at it in a mo
Old 09-10-2004   #4
GP T-Jet Owner
activematt's Avatar
Trader Rating: (0)
activematt has donated! United Kingdom
Re: radio removal
Your best bet is to use a cut up coat hanger, thats what i used to get my old radio out, and strangely is what Fiat suggested for me to use.
Sold: 02 (52) Sassi Grey Stilo 1.6 Active, Full Merkur Bodykit, MS Design Spoiler, 18" Lenso Shu Wheels, 50/40 Drop, Ragazzon Quad Exhaust
Now: 07 (57) Crossover Black Grande Punto 1.4 Tjet 120 Sporting....Standard
activematt is offline
Old 09-10-2004   #5
Trader Rating: (0)
Re: radio removal
I borrowed a set of Radio removal tools from a mate, and found the quality of the clips on the Stilo radio is mince, and they wouldn't grip. So i took out the upper glove box in preparation to fit the new glovebox liner, and reached behind the stereo and pushed it out from behind. Worked a treat!
53 plate, Stilo 3-door, Sassy grey, 17" Claw Alloys, Falken Ziex Z512 tyres, 1.2 Active -- 45mpg!
StiloBoy is offline
Old 09-10-2004   #6
Grim_Evil's Avatar
Trader Rating: (0)
Re: radio removal
mm, for some reason my cd/mp3 player will not work with the stilo iso connector?? do i have to change some wires around or something first????
Old 09-10-2004   #7
5vp3r m0d
Stu DemonD's Avatar
Trader Rating: (1)
Re: radio removal
Some old posts that came up on search that may interest you:
http://www.fiatforum.com/showthread....ht=radio+stilo
Btw, this original thread seems to have come up a multitude of times; search on 'radio stilo' and see what I mean
Old 09-10-2004   #8
Grim_Evil's Avatar
Trader Rating: (0)
Re: radio removal
from what i have found outI think I got this right, going to give it a try in the morning)
RED wire (Perm 12v) which connects to my orange (memory permanet +12v)
BLACK wire (ground) which connects to my black cable(ground)
then theres these two in the stilo???
RED/WHITE wire (what this one for??)
RED/BLACK (and this)
on my unit i have two more wires
orange/white (for auto aerial) no use on the stilo as its a fixed one
red (igition switch) so could this go to one of the stilo cables to switch the unit on and of with igition maybe???
I can not find any info on these two wires(stilo ones) anywere??
Old 10-10-2004   #9
Grim_Evil's Avatar
Trader Rating: (0)
Re: radio removal
anyone???
Old 11-10-2004   #10
purplemonday's Avatar
Trader Rating: (0)
purplemonday has donated!
Re: radio removal
Basically the stereo wiring on the Stilo is a pain in the arse as FIAT have decided to use their own wiring scheme.
I recently fitted a Sony CD head unit in place of the standard radio/cassette and had to do a bit of DIY on the Sony loom to mate it up with the FIAT one as there is no switched live (the switched live is provided by the CAN system (i.e. from the body computer) and therefore only works with factory head units!).
The other 'fun' item was that the Sony loom provides a set of bullet connectors so you can bypass the switched live thus allowing you fo fit it straight into any car...apart from a FIAT!!! This is because in their infinite wisdom FIAT decided to wire the permanent live to a different pin on the ISO block rather than use the 'standard' pin assignments - got round this by re-wiring the Sony ISO to match the FIAT loom however you could buy a straight through ISO extension cable and 'cross' the necessary wires to acheive the same thing.
So pretty much the only two wires on the power segment of the FIAT ISO that do anything are the Red and Black - the others are not live and I believe are only there to allow the factory units to communicate with the CAN system.
Anyway, hope this helps a little but let me know if you've got any other questions.
John
Stilo 1 Volvo 0
Old: Stilo 1.6 Active 5 door in Crystal Green
New: Audi A4 SE 1.9TDI 115
purplemonday is offline
Old 11-10-2004   #11
Grim_Evil's Avatar
Trader Rating: (0)
Re: radio removal
thanks, i will have a other play with it tonight when i get home:<
Old 11-10-2004   #12
Grim_Evil's Avatar
Trader Rating: (0)
Re: radio removal
well its in now and working(i had to join the red and orange leads together to get it to work.(good job i had both my cd/mp3 manual and the fiat one)
Old 17-10-2004   #13
Get Your Own Title
Neofolis's Avatar
Trader Rating: (0)
Neofolis has donated! United Kingdom
Re: radio removal
Do you get the impression Fiat don't want anyone replacing the factory head unit? I've got a fascia for a normal din head unit, but I'm sure it would make the cabin look a bit spartan. Has anyone got any pics of a replacement head unit installed, so I can see what it looks like with all the extra plastic?
Neofolis is offline
Old 17-10-2004   #14
Grim_Evil's Avatar
Trader Rating: (0)
Re: radio removal
there are from a other persons headunit, and facia, mine has a little shelf under the headunit, so it does not look so spartan
ID:	979  Click image for larger version
Old 17-10-2004   #15
Cymru Am Byth!
blackJTD's Avatar
Trader Rating: (0)
blackJTD has donated! United Kingdom
Re: radio removal
Grim, you've got a left hand drive! did u import that or buy it over here?
Ex 3dr Stilo JTD in black (155bhp)
Ex 3dr Stilo Abarth in Chrome Grey
blackJTD is offline
(G) Radio removal arc Punto 0 07-09-2004 18:13
(G) Punto radio removal Dave Harris Punto 9 24-04-2004 11:44
Stilo Factory Fitted Radio Removal sradams1977 I.C.E 2 27-12-2003 12:44
Fitting a new radio to a Fiat Uno (1992) stuw I.C.E 0 20-09-2003 01:35
(G) Stilo Radio Removal monster109 Stilo 6 18-08-2003 02:50
