| Pollen Filter I would be grateful if anybody could tell me where the pollen filter is and how to change it on an 02 1.6 Thanks Chris
| open the drivers door,kneel down,lean into the car and touch the clutch pedal then move your hand over to the plastic center console trim panel and it`s behind this,very carefully pull the trim towards you, it will argue but be gentle as they can crack. when it`s off use a torch and look again at the heater beside the pedals you will see a black trim panel about 2cm wide and 20cm tall this unclips and there is the filter,it pulls out ok but new one will not go in easily. Have fun!!!!!
| | courtland32 | Stilo | 3 | 12-06-2004 04:29 |
| | newportz | Punto | 3 | 02-06-2004 14:10 |
| K&N Air Filter in a panda? | panda power | Panda (Classic) | 24 | 29-05-2004 00:02 |
| | max | Cinquecento / Seicento | 11 | 22-05-2004 05:23 |
| | yellow_sei | Cinquecento / Seicento | 7 | 04-01-2004 23:06 |
