The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 07-10-2004   #1
Trader Rating: (0)
Airbag Failure Warning Light
Hi All
I have a Stilo Abarth which is displaying the 'Airbag Failure Warning' on the dash. On occasion it does disappear, for a very short periods of time, but most of the time its displayed. The car has not been hit and the airbags haven't, as of yet, deployed.
Is this a common fault ? is it easy to fix ?
dexys is offline
Old 07-10-2004   #2
5vp3r m0d
Stu DemonD's Avatar
Trader Rating: (1)
Stu DemonD has donated! United Kingdom
Re: Airbag Failure Warning Light
Hello Dexys,
I frequently get the airbag warning light on, and other faults - it seems it is all part of the Stilo/FIAT electronics, and maybe over sensitivity. What happens when you first switch the car on? Does it say OK after it does all its internal checks?
Have you had the car put on Examiner at the local dealer, or at least approched them yet?
Stu
Electroclash Panda 100HP
Red brake calipers - done / Red highlights on engine cover - done
Red GSR kit - done / Red badges - done / Cobra springs - done
Stu DemonD is offline
Old 07-10-2004   #3
Trader Rating: (0)
It goes through the system checks OK and then approx. 5-30 secs later beeps and up pops the warning.
No haven't taken it to the dealer yet....
dexys is offline
Old 07-10-2004   #4
DOG
DOG's Avatar
Trader Rating: (0)
i had this on my 1.6. it was the sensor in the passenger seat.
DOG is offline
Old 07-10-2004   #5
Ned
Trader Rating: (0)
Thumbs up Re: Airbag Failure Warning Light
It will be a poor multiplug connection somewhere but your car has approx 8 airbags it will need a examiner read out to i.d. the cause, the favourite ones are the plugs under the seats (as previously mentioned) but dont go fiddling with them just get the dealer to rectify.
Ned is offline
Old 07-10-2004   #6
braden's Avatar
Trader Rating: (0)
Ditto on my abarth.
braden is offline
Old 07-10-2004   #7
jasper's Avatar
Trader Rating: (0)
Talking Re: Airbag Failure Warning Light
Also ditto on my 1.6 they replaced the occupant sensor and on a seperate occasion the wiring loom - eventually it stayed fixed...
Stilo Abarth manual/Techno Grey/Grey-Cream leather/17inch alloys/BMC Carbon Dynamic Airbox/Angel Tuning Re-map/Road Angel Navigator
Citroen C4 2.0 HDI VTR+ Red/17 inch alloys/& lots of toys! (my work car), which is why its not a Fiat!!
jasper is offline
Old 07-10-2004   #8
Noz
Noz's Avatar
Trader Rating: (0)
Take it the ealers asap...mine did the same and then the steering wheel controls went
took it in for an hour and now all is well...
3Dr STILO ABARTH 52 plate 2003..Silver,Leather,
Sky roof
"Am I alive and dreaming or am I dead and remembering..."
Noz is offline
Old 07-10-2004   #9
Trader Rating: (0)
at last some dealer knows how to f*****g fix things!!!!
lalli is offline
Old 07-10-2004   #10
Trader Rating: (0)
Be aware,
I had the AA out to mine for a sensor warning light and he told me that if ever the airbag warning light came on pull over and get towed to a dealer because the Stilo is the only car that when the airbag warning light illuminates theres a likelihood the bag will inflate.
philmgro is offline
Old 08-10-2004   #11
Trader Rating: (0)
Many thanks,
It'll be off to the dealers ASAP.
Thanks for the advice and help.
dexys is offline
Old 08-10-2004   #12
Glutton for Punishment
Rich's Avatar
Trader Rating: (1)
Rich has donated! United Kingdom
Philmgro, don't listen to that AA bloke, that was a load of crap.
If you read the Stilo CD (bear in mind it is all based on the BOSCH EBD II, fitted to BMW's etc), if an Airbag component is suspected of failing, the Airbag Node is deactivated completely. It's quite the opposite; have a collision, and NO airbags will be deployed.
07 Bravo TJet Sport, Maranello Red
Factory Options: Dual Zone Climate, 18" Alloys
Retrofitted: Armrest with conditioned foodbox, Stainless Kick Plates
Sister's: 06 Grande Punto 1.4 Dynamic, Crossover Black, Red Badge Conversion
Rich is offline
Old 10-11-2004   #13
StiloJoe's Avatar
Trader Rating: (1)
i have had mine a month now it is a 53 reg (jan 2004) and it has happened twice I rung my dealer up (derby) and he said it could be a bigger job or a peice of piss job
It was in the end a wiring loom underneath the drivers seat (load sensor) and if you nunged it, it would go on or off but would correct it if it was on
Hope this helps people
J
StiloJoe is offline
Old 10-11-2004   #14
Veracocha
bozzy's Avatar
Trader Rating: (3)
bozzy has donated! United Kingdom
Yep, it's happening to me again. While you wait to get it looked at press the menu button and the warning display and annoying beeps de-activate.
bozzy is offline
Old 10-11-2004   #15
James M's Avatar
Trader Rating: (0)
Firstly, airbags are a 'fail safe' system, which means if they fail, they will be deactivated and hence can't operate.
I've had this problem a couple of times, first time a fiddle under the seat sorted, but second time the dealer need to clear the fault.
James M is offline
(T) Airbag Warning Light vyore Stilo 15 24-01-2005 23:53
(G) AIRBAG warning Light joes Marea 8 29-09-2004 22:43
(T) Airbag failure warning in 2004 Punto gfotopou Punto 27 06-08-2004 08:29
(T) Stlo Bulb Failure Warning light Brad Stilo 9 06-04-2004 20:07
(T) Airbag warning light stays on coupe2004 Punto 5 31-12-2003 05:51
