The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 29-09-2008   #1
Trader Rating: (0)
1.2 stilo start up problems
hi, would anybody be able to help me, i have a 1.2 stilo arbath model which i am about to put up for sale - i have a slight problem when i try to start her up..... sometimes it will take 3/4 times to get the engine runnin as it just keep turning over -does anybody know wether it could be anything other than the starter motor? would be very greatfull for any response
chrisslater is offline
Old 30-09-2008   #2
jug
blessed are the apostates
jug's Avatar
Trader Rating: (1)
jug has donated! United Kingdom
re: 1.2 stilo start up problems
it cant be the starter motor if the engine turns over.
if the code light remains lit on the dash when it does not start then the problme is the aerial around the ignition switch. a wiggle of its connector should sort it.
a common cold starting problem on the 1.2 is a loss of compresson from a head gasket leak. on the 1.2 a head gasket leak can go unnoticed, not using any oil or coolant or even causing a noticable misfire, yet the low compression makes cold starting difficult. if you only have problme starting the engie when it is cold then a compression test is needed.
a common warm starting problem on the 1.2 is the crank sensor. if you only have problmems starting the engine when it is warm (been used recently) then the crank sensor should be top of your list.
if the starter motor turns more slowly than you would expect then a poor battery is most likely, although dirty battery contracts and a rotten earth strap (from gearbox to chassis) are also possibilites.
jug is offline
computer start up problems Big Black Stilo Computing 26 12-04-2008 12:42
(G) Won't Start after problems samwilliams333 Punto 2 14-03-2007 21:35
Start problems Damian99 Tipo 15 06-05-2006 22:44
pc problems at start up The Negotiator Leisure Lounge 10 26-03-2005 20:02
