| gauges droping to zero and car runs checks as i'm driving! help hey guys anyone had problems with the body computer on 1.2l 2002 stilo's? weird messages, the clock and date keep resetting, as I'm driving the car keeps running system checks (as it does when you first start the car) then engine fault light, airbag light and the rev, speedo fuel and temp gauges drop to zero for a sec and back up again, however the engine is running fine throughout? help and one know where i can get a virgin body computer for cheap!!! i'm told it costs between €500 and €550 euro plus vat.
| | #2 | |||
| It's about GO! not SHOW! | Re: gauges droping to zero and car runs checks as i'm driving! help
More likely a bad earth issue I'd have thought or a bad node on the CAN line.
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | |||
| | #3 | ||
| Re: gauges droping to zero and car runs checks as i'm driving! help Hi, Disconnect the battery for more than 1 hour. Next see if the problem is solved. Maybe one of the ECU's has a data problem and needs a good reset. I have had 3 times this kind of problems. Oh, and be sure the lights are off when you connect the battery or else the light bulbs blow out instantly. OldMan.
__________________ Fiat Stilo 1.9 JTD 115 Pk Dynamic, 5 Doors, from Sept. 2003. | |||
| | #4 | ||
| Re: gauges droping to zero and car runs checks as i'm driving! help tried cleaning the d4 connecter and disconnecting the battery, neither have had any effect!! feel like i'm gettin no where
| | #5 | ||
__________________ Stiloman | |||
| | #6 | ||
| Re: gauges droping to zero and car runs checks as i'm driving! help Sounds very familiar. Check out :- http://www.fiatforum.com/stilo-techn...02-1-9jtd.html
| Tags |
| body computer, electrics, stilo |
| | Horatio | Punto | 3 | 16-04-2008 18:14 |
| | BRAVARulez | Bravo / Brava | 4 | 10-04-2008 11:42 |
| | danni06 | Bravo / Brava | 3 | 10-12-2007 07:15 |
| Who runs there car on Vegetable oil? | oldskoolmk1unoturbo | Leisure Lounge | 26 | 02-12-2007 18:18 |
| | chubbston | Cinquecento / Seicento | 33 | 13-09-2004 20:03 |
