The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 12-09-2008   #31
Trader Rating: (0)
Re: Head gasket, piston ring or sticking volve problem?
Try disconnecting the air inlet pipe off the manifold (next to the EGR valve) and starting it from cold, wait till the smoke clears, stop it, leave it, start it again next day. If you don't have smoke, then it is coming in through the inlet pipework (ie from the turbo or breather / vapour trap pipes). If you have smoke, it is coming from inside the engine, i.e. piston rings, valve guide seal etc.
WANTED: Faulty Connect Nav+ for parts, to fix mine.
john55 is online now
Old 12-09-2008   #32
It's about GO! not SHOW!
Argonought's Avatar
Trader Rating: (0)
Argonought has donated! United Kingdom
Red face Re: Head gasket, piston ring or sticking volve problem?
Originally Posted by john55 View Post
I think you will find it is the wastegate.
To be pedantic about I think you'll find the JTD115 doesn't have a waste gate in the excepted sense although I concede it uses a mechanism that accomplishes much the same task.
Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic
Argonought is offline
Old 12-09-2008   #33
fiat brava jtd elx 105's Avatar
Trader Rating: (0)
every turbo has a waste gate other wise the turbo would just spin faster and faster and then blow up
TURBO
fiat brava jtd elx 105 is offline
Old 13-09-2008   #34
Trader Rating: (0)
I like the idea but I have trouble to locate the pipe you mentioned.
On the other hand, I save 2 vapour recovery pipe on the top of the engine. I am puzzled about their function and design.
1). The red one in the font. Why does it directly get into the turbo intake? Oil vapour will get into the turbo and then to the intake directly....
2). Where is the blue vapour pipe goes to? I saw it get into the engine in back.
Thanks again in advance.
shiningliao is offline
Old 13-09-2008   #35
Argonought's Avatar
Trader Rating: (0)
Lightbulb Re: Head gasket, piston ring or sticking volve problem?
The JTD80 does indeed have a waste gate but not so the JTD115 which is fitted with a VGT (variable geometry turbo)
This the the actuator controlled directly by the overboost valve and you can just see the actuating rod (top middle). Notice the tube at the bottom which returns to the overboost valve (otherwise known as a VGT solenoid)
This directly controls the geometry of the blades on the turbo and therefore controls excessive boost in a much more efficient way than a waste gate.
Old 13-09-2008   #36
Trader Rating: (0)
Another question about my dying stilo...
I can reproduce the problem:
When start the car, turn the key to 'start' immediately without waiting for the engine check, glow plug indicator go off...etc. This cause my JTD engine unable to start up properly. Even after couple minutes, restart again with proper check done. It still unable to start... It just like a petrol engine without spark plug. There is no ignition. Eventually, after long wait and long keep starting it. It get back to normal.
Don't quite understand the reason. Any idea?
Old 13-09-2008   #37
Trader Rating: (0)
Forgot the diagram... Here it is.
Old 13-09-2008   #38
Trader Rating: (0)
Wow, thanks! However.... geometry of the blades on the turbo....
This is beyond my knowledge. Can you explain what exactly is that blade? I am quite interested to know these stuff.
Old 13-09-2008   #39
Argonought's Avatar
Trader Rating: (0)
If your JTD engine is cold then you should always allow time for the heater plugs (glow plugs) to warm the cylinders (so the fuel will ignite). This is the same for any diesel.
The large intake (about 8cms dia.) tubing that john55 refers to is towards the back and you need to remove it from what looks like a carburetor on the inlet manifold. It will be easier if you remove the engine cover first. It sounds like a good test to me so I'd do it but never drive with it like that as it's taking in completely unfiltered air.
Old 17-09-2008   #40
NobodyBlamesTheHappyGuy:D
Morty Mort's Avatar
Trader Rating: (1)
Morty Mort has donated! Norway
The killer reply: Is the oil filter fully tightened? If not it causes a pressure leak and oil evaporates and spills out - but you will never notice anything apart from believing the engine drinking oil. Also ceck if the seal is moist or dried up. Or if there is an extra seal from an earlier change. If so, remove it as it will never tighten correctly.
Just trying with an extremely simple solution.
M.
jet blue. 17" blades. eibach pro system. omp bar. gsr breath. mattig face. debadged. phoenix gold watts. rear tint.
member of the 5-door massive attack.
Morty Mort is offline
Old 25-09-2008   #41
Trader Rating: (0)
Just want to post some updates for my sick JTD status and give a conclusion for this thread.
A friend's friend who work in gargage check my JTD. He said he's sure engine is good. No head gasket problem or piston ring issue. He believes it's electronic problem.
I wasn't very convinced with his diagnose because I done a computer check in FIAT dealer. Report shows nothing wrong. From my understanding, this computer check should rule out all the electronic problems.
He changed the MAF sensor for me and amazingly.... problem improves a lot! Not completely gone but much better.
Now, I don't trust computer check that much. My plan for now is:
Clean all the oil dirt around turbo and it's pipes. Hopefully this could find out the source of oil leak and narrow down the root cause. I'll reading all the relavent threads and will start a new thread to ask help soon.
Old 26-09-2008   #42
Argonought's Avatar
Trader Rating: (0)
Examiner will only report faults - not a sensor just being out of tolerance.
Don't forget you can go for a drive with Examiner connected and if configured correctly it will report actual MAF readings vs predicted readings.
A good technician should then be able to judge if a sensor is suspect.
The trouble is it's often cheaper to just change the part than pay for diagnosis.
You should have done that weeks ago
(G) punto 16v valve head gasket which one ?? Xsisley Punto 4 12-04-2008 01:03
(T) punto 16v valve head gasket which one ?? Xsisley Punto 0 27-01-2008 14:17
(T) HELP Piston Ring Badger_Benji Punto 0 06-04-2006 22:01
(T) HELP Piston Ring Badger_Benji Cinquecento / Seicento 0 06-04-2006 22:01
Custom piston ring/piston liner website T.E.D. Jordan Leisure Lounge 3 31-12-2005 03:20
