| stilo 1,6T hi, i am a happy owner of a stilo 1600 turbo.... the car does a 0-100 in 7,9 at 0,7bar.... all i want 2 ask is if anybody knows any langer fuel injectors(is that right??) 2 spray 250cc.... thanx in advance....
| Re: stilo 1,6T
__________________ New:Clio Sport 172 Cup Old: Punto Sporting 16v MK2, Abarth Kit, Abarth Alloys, GMax AirFilter, Angel Tuning, ICE Install, Plus other bits | |||
| | #3 | ||
| Re: stilo 1,6T they don't..... i tuned it....
| | #4 | ||
| Re: stilo 1,6T
| | #5 | ||
| Re: stilo 1,6T 3800E incl. gauges (halmeter, barmeter, oiltemp, turbo temp.) and turbo timer.., garret t25, intercooler, pipes, ecu paralel, blowoff valve and oil freeg. once i did a dynotest during summer it showed 156bhp at 0,5bar (36oC ex temp) and 22,8kgr mom. now it must be around 180 at 0,7bar (25oC ex temp)......
| | #6 | ||
| Re: stilo 1,6T Sweet, sounds like a nice motor mate ![]() Try get some pics on here (inc. engine pics) so we can all have a good nose
| | #7 | ||
| Re: stilo 1,6T
| | #8 | ||
| Re: stilo 1,6T Did you lower the compression, if you didn´t the T would stand for timebomb (i know i´ve done it lots of times, 0,7bar is not to be used on HCR engines)And 180hp coming from a 1.6Turbo would not be a lot of power ![]() (i´m not flamed or saying it isn´t possible just wrong if the compression is stock)
__________________ ![]() http://smokeme.coconia.net/index.htm http://turbofire.no.sapo.pt/index.htm http://nelsonsmoke.hi5.com/ Last edited by smokeme; 25-08-2004 at 17:49. | |||
| | #9 | |||||
| Re: stilo 1,6T the compression rate is now down to 8,2:1 i would't anything like that if a didn't lower the compresion.... a lot of fuss 4 nothing...max 0,4 bar.....
using stock pistons??????? i am just waiting 4 the new forged pistons to go 4 1,0 bar... honestly i think that 180bhp from a light turbo conversion is a lot...
| | #10 | ||
| Re: stilo 1,6T How did you lower the compression and used stock pistons!! | |||
| | #11 | ||
| Re: stilo 1,6T hmmmm...what is the name..... i changed that part that is within the engine block and the valves with a thicker one..... u can also use 2 or 3 of that part one on top of the other... it is the cheepest way to play with compression values....easy.. the best way though is 2 get a set o forged pistons and increase the pressure to 1bar and over... this is why i say it is a light turbo conversion
| | #12 | ||
| Re: stilo 1,6T Thicker Cylinder Head Gaket?
| | #13 | ||
| Re: stilo 1,6T
| | #14 | ||
| Re: stilo 1,6T i am afraid that there is no way u could get an xtra 50ps without using those parts i've mentioned cause u would't want the pressure to exceed 0,3 bar.... u defently need to either place an extra fuel injector, or replace them with 4 new spraying about 250cc instead of 150cc... u wont need 2 replace the fuel pump as the pressure of the stock pump can be increased up 2 3,5 just by playing with a little metalic thing that it has on... all the parts r made from my mechanic (ecxept from the turbine of course), and the parallel ecu which is programmed with a laptop on my stilo is programed by a greek guy who has s/ing like 3 degrees in comps and mechanology...Digital tech is the firms name.... if u ever come 2 greece (we are neighbors i see) i' ll show u... ![]() greetings to cardiff where i spend 4 amazing years...
| | #15 | ||
| Re: stilo 1,6T | |||
| | JR Graville | Stilo | 108 | 12-09-2004 16:11 |
| FREE Club Stilo Stickers! | twincamms | Leisure Lounge | 0 | 03-05-2004 20:19 |
| Club Stilo Stickers! | twincamms | Lets Talk FIAT | 0 | 03-05-2004 20:04 |
| | stilo | Stilo | 35 | 19-04-2004 21:40 |
| | Roberto | Stilo | 0 | 14-07-2002 22:06 |
