| I just have buyed a Elm5 Bluetooth to connect on my Stilo 1.8 8v 2003 (Brazil), using the Scantool.NET or ScanXL, the both apps doesn't connect with my car!!! ![]() Any body obtain a successful connection with Elm 5??? thks...
| It's about GO! not SHOW! | Re: OBDII Elm5 Bluetooth on Stilo 1.8 8v 2003 Should be OK. Are you sure you've pushed it onto the car's OBD connector firmly enough. Need a bit more info to comment really.
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | ||
| | #3 | ||
| Re: OBDII Elm5 Bluetooth on Stilo 1.8 8v 2003 mine works. i use scantool too.
__________________ | |||
| | #4 | ||
| Re: OBDII Elm5 Bluetooth on Stilo 1.8 8v 2003 Would a 2003 Brazilian Stilo have been OBII compliant? In Europe it was 2001 for petrol and 2004 for diesel cars. Dave.
__________________ If all else fails.. read the instruction book. | |||
| | #5 | ||
| Re: OBDII Elm5 Bluetooth on Stilo 1.8 8v 2003 Which OBD is the question. In europe we use EOBD2 (European OBD2) and the US use a slightly different standard although I understand they are bascially compatible but there could be some differences.
__________________ WANTED: Faulty Connect Nav+ for parts, to fix mine. | |||
| | #6 | ||
| Re: OBDII Elm5 Bluetooth on Stilo 1.8 8v 2003 I will try to connect with my notebook and later i will post the error displayed on ScanXL... The Elm5 have been tested with success on VW Polo 2003. My ECU is a "Delphi HSFI 2.3".
| Tags |
| obdelm5bluetooth |
| | dave_5150 | Stilo | 6 | 27-04-2008 13:33 |
