The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo > Stilo > Technical
Old 06-08-2008   #1
Trader Rating: (0)
LO BRAKE FLUID, no right indicators, can't open boot ???
Hi everyone!
Very strange thing happened to my Stilo 1,6 16V 3D some time ago.
I was driving one evening, everything as normal, over the sudden LO BRAKE FLUID warning light appeared - out of the blue. I was very suprised, as just went through major service. Checked the level - spot on! up to the level. on top of that at the same time my right indicators - they don't work, although when I open/close the car, or switch on the emergency lights all the "yellow lights" are blinking - both sides! I also can not open the boot by pressing the "soft touch" button on the boot, I only can open it by pressing the button on the key - it doesn't matter what I set on the computer - on or off - it still won't open.
i have checked the connections inside the rear panel soft touch button, rear boot motor, everything spot on, all connecting perfectly, but somehow the signal from central locking doesn't get there...
i went to FIAT garage, they tested it with EXAMINER....and they don't know, they say it could be rear right side lamp that gives artificial signals messing up the body computer - I've checked it, gave it a clean, spot on - it could not be any simpler by the way - no problems what so ever with the lamp (cost ca100£ at FIAT garage to have it replaced as you have to have it done as entire module as thay don't brake it into front and rear panel) then I put the lamp back again...still the same LO BRAKE FLUID - STOP THE ENGINE...BEEP BEEP BEEP...no right indicator, can't open the boot ......any ideas?
it's great forum by the way!
stilofun is offline
vB code is On
I cant open my boot? Ry4n Grande Punto 5 29-04-2008 21:32
cant open the boot gaz.d Marea > Technical 4 14-02-2008 09:42
How do I open boot sptaylor75 Panda (New) 9 27-09-2007 22:09
My Punto needs Brake Fluid, isit a certain one i must get or any brake fluid will do? keepinitcriss Punto > Technical 5 02-04-2007 17:30
Boot Won't Open MattMk1 Punto > Technical 5 12-03-2007 09:25
