The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo > Stilo > Technical
Old 4 Weeks Ago   #1
Big Black Stilo's Avatar
Trader Rating: (0)
brake light woes
about 2/3 weeks ago my passenger side brakelight blew, car told me this and indeed wasnt working.
i took out the bulb which was blown, so i replaced it all. No problems there then.
then, about wednesday this week, i had to emergancy stop. on doing so the bulb failure message came up for the passenger side. But during the drive hime it was flickering on/off and really getting on my tits.
I got someone to stand behind the car while i activated the lights, and it wasnt working. Then the message went and it was working, so checked for loose connections, bulb condition, type, etc and all is fine. i even popped a new bulb in as well
The rest of this week i have had intermittant bulb faults from that side on the brake light, and a work mate who followed me said sometimes it was working, sometimes it wasnt.
This is confusing the hell out me now as its only effecting one side. How does the bulb warning system work and how is it earthed to the car?
I NEED HELP!!!
Fabbrica Italiana Automobili Torino
Big Black Stilo is offline
Old 4 Weeks Ago   #2
It's about GO! not SHOW!
Argonought's Avatar
Trader Rating: (0)
Argonought has donated! United Kingdom
Re: brake light woes
As you suggest, most likely a bad connection/earth somewhere in that area.
I'd remove BOTH light clusters if I was you and carefully check for any connection issues - can be useful to transpose bulbs too.
Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic
Argonought is offline
Old 4 Weeks Ago   #3
Trader Rating: (0)
im thinking it maybe an earth issue.
how does the car pick up a bulb fault anyway? i noticed it does it without the lights actually being switched on.
and although this maybe sill but is the cluster earthed through the three connection bolts that hold the cluster to the car?
I NEED HELP!!!
Old 3 Weeks Ago   #4
Trader Rating: (0)
nobody know how the car detects a bulb fault?
I NEED HELP!!!
Old 3 Weeks Ago   #5
Argonought's Avatar
Trader Rating: (0)
Lightbulb Re: brake light woes
There are only two ways - resistance checks of the filament or an optoelectronic sensor. The latter is foolproof, as it measures photons, but is liable to go faulty itself.
The Stilo almost certainly measures circuit resistance to check for faulty bulbs which means, using low voltage, it can detect a faulty bulb without actually illuminating the bulb itself. It's likely to be based on a variation of the Wheatstone Bridge principal.
It will detect open filament faults (the most common bulb failure by far) very effectively but I suspect it may be fooled by shorted filament faults.
Old 3 Weeks Ago   #6
Whaddya mean too old?
Deckchair5's Avatar
Trader Rating: (0)
Deckchair5 has donated! United Kingdom
Yes, check carried out on resistance/ return voltage -if the resistance isn't right then it will fire up a failure even if the bulb itself it fine. Best to imagine it's saying "Brake light circuit failure"
02 Stilo 1.6 Dynamic 3 door
99 Bravo 1.2SX
Deckchair5 is offline
Old 3 Weeks Ago   #7
Trader Rating: (0)
ok, so i've checked in situe and indeed, it is not working.
so i dismantled it and yet again the bulb is fine. i swap bulbs over from the other side, test it for 5 or so minutes, no problem.
re assemble, get 5 minutes down the road and beep beep beep stop lamp failure on the passenger side, again, and the light is not coming on.
no damage on the cluster board and the bulb in that side now is the fiat original, and that bulb isnt blown
I NEED HELP!!!
Old 3 Weeks Ago   #8
Deckchair5's Avatar
Trader Rating: (0)
I had a poor contact on mine where the connector attaches to the light cluster circuit board giving the same warnings as you have. A clean up there with a normal pencil eraser or contact cleaner and some very careful moving out of the connector pins to make a better contact and have never had a warning since.
99 Bravo 1.2SX
Old 3 Weeks Ago   #9
Trader Rating: (0)
cheers decks, i'll have a crack when i find my needle-nose pliers
I NEED HELP!!!
Old 1 Week Ago   #10
Trader Rating: (0)
ok, i have made sure the connectors are not pushed down and away from the bulb- again, worked for 5 minutes then beep beep beep
so cleaned up the contacts and again, beep beep beep.
the only thing now is it is flicking up the fault every couple of minutes so all im getting is beep beep beep every 2 mins, which is annoying.
I NEED HELP!!!
Old 1 Week Ago   #11
Trader Rating: (0)
my stupid passenger side brake light is doing the same, does it for a few days then works fine for a day then the god dman beeping begins all over, i was guna buy a new bulb, but what about the connectors you are on about, what are these and where are they and what should i clean them with?
Stuart_89 is offline
Old 1 Week Ago   #12
Trader Rating: (0)
the connectors are the pieces of metal at the bottom of the bulb carrier on the cluster.
im starting to think my wiriing got damaged when i changed the bulb
I NEED HELP!!!
Old 1 Week Ago   #13
Deckchair5's Avatar
Trader Rating: (0)
I'd make sure you've got a good earth at the cluster. Jam something on the brake pedal and turn ignition on, now put indicator on for that side. Watch the brake light and see if it dims in time with the indicator. If it does, do a voltage drop test between the bulb earth and good earth point at the rear. Again anything over the magic 0.2v and there's your problem
99 Bravo 1.2SX
vB code is On
injection light woes ian lisi Multipla 1 06-04-2008 12:34
Help Brake Disk Woes Markstrachan Bravo/a > Technical 5 31-07-2006 19:41
Battery Light Woes Jetsfan5 Cinq/Sei > Technical 7 20-08-2005 22:08
Brake Woes GeX Cinq/Sei > Technical 10 27-07-2005 21:06
Brake Hose, and new Rear Caliper woes... euan Stilo > Technical 7 17-07-2005 23:20
