| Vibration 1500-2000 rpm I don't know if i'm being a 'nervous nelly' but i seem to be getting viration at 1500-2000rpm when in neutral. I've recently had a service, including cam belt kit, spark plugs and coil packs. Am i just thinking the worst, i can't seem to remember it before, but i could be wrong. Also there is a bit of juddering when cold, i'm hoping this is not the clutch , cos it can't be the plugs or coil packs!
__________________ 2002 Abarth- Totally original Last edited by jpholroyd : 01-08-2008 at 11:06. | |||
| Re: Vibration 1500-2000 rpm It is quite possible that they fitted the wrong grade of spark plugs.
__________________ WANTED: Faulty Connect Nav+ for parts, to fix mine. | |||
| | #3 | ||
__________________ 2002 Abarth- Totally original | |||
| | #4 | ||
| Whaddya mean too old? | Re: Vibration 1500-2000 rpm To have a mismatch only at a certain rpm then I'd be more suspicious of your cam belt change and suspect they got the timing wrong- yet another one as it seems to be very common that garages guess and don't check the timing is set up properly BEFORE they give it back to the customer If you noticed it immediately after the cambelt change then there's your answer
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX | ||
| Engine noise between 1500 and 2000 in 2nd gear | maxupixu | Grande Punto > Technical | 3 | 15-07-2008 22:56 |
| noise at 2000 rpm | k222pjr | Barchetta | 9 | 03-01-2008 11:11 |
| Stilo Multiwagon 1.6 Vibration at 750 rpm - no one can find what is going on ! | GSTAVARIS | Stilo > Technical | 4 | 04-07-2007 14:36 |
| 1.6 Engine Vibration 2200 rpm | stilo27 | Stilo > Technical | 9 | 14-11-2005 15:16 |
| idle speed at 1500 RPM | hammerskin65 | Cinq/Sei > Technical | 9 | 02-08-2005 12:54 |
