The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo > Stilo > Technical
Old 30-07-2008   #1
LeeStilo's Avatar
Trader Rating: (0)
warning light
ive noticed when i go over some speed bumps (not fast) that the orange light with the triangle flashes up and flickers then goes off, then the car kicks back in - what is wrong now with the wonderful machine?! lol
My Fiat Stilo 1.8 16v Dynamic: CLICK HERE FOR THE GARAGE
Hertz set up
Clarion DUZ388RMP head unit
LeeStilo is offline
Old 30-07-2008   #2
Big Black Stilo's Avatar
Trader Rating: (0)
Re: warning light
does it have an exclamation mark in it?
and what do you mean the car kicks back in? is it cutting out?
IMPORTANT ANNOUNCEMENT!!!
Fabbrica Italiana Automobili Torino
Big Black Stilo is offline
Old 30-07-2008   #3
Trader Rating: (0)
Re: warning light
well the orange triangle is used mainly for speed limit exceeded but it is also used, alongside the matrix display, to indicate other faults. these are:
  • fuel cut off switch on
  • warning light failure (as in the ABS, ASR, steering, brake warning or ESP light blown)
  • sensor failure on coolant and oil pressure or anti pinch on windows
so if your cars not cutting out i bet theres a loose wire about that creates a fault but re-connects before the matrix tells you the fault.
It does come up for other things but not on a petrol model
Old 30-07-2008   #4
Trader Rating: (0)
Re: warning light
Hello,
If its the warning triangle with the circle round it, it could it be the traction control light which flickers when the car's traction control kicks in? It could loose traction as you go overthe speed hump (I would have thought that you would have to hit it quite hard/fast, which your not) I know from my works car you can get the this light to flicker quite easily, the power cuts, then kicks back in as the light flickers. Only an idea!!!!
Natty
nattyfatty09 is offline
Old 30-07-2008   #5
LeeStilo's Avatar
Trader Rating: (0)
Re: warning light
Originally Posted by nattyfatty09 View Post
Hello,
Natty
yeah seems its like that, ill try get a look at the light exactly its on the rev counter in the middle triangle with an exclamation mark sounds right! the car doesnt cut out just once im over the bump theres a little tug and back to normal, hard to explain
Hertz set up
LeeStilo is offline
Old 30-07-2008   #6
Falling Into A Trap
Joshua Frost-Lunn's Avatar
Trader Rating: (0)
Joshua Frost-Lunn has donated! Jamaica
Re: warning light
if you have your foot down a bit the car might loose contact a bit and try and spin the wheels.. therefore the traction control cuts the power back and so no more acceleration at the same rate.. then lets you accelerate fine after a while
FIAT STILO..... ABARTH IN DISGUISE
SCORPION BADGES, SKYROOF, 17" ANTHRACITE BLADES, ABARTH SIDE SKIRTS AND SPOILER, BLACK OUT WINDOW BLINDS
PREVIOUS: 54 CORSA 1.3CDTI SXI - WRITE OFF
05 MICRA 1.2 16V SE - IN PURPLE - PART EX
Joshua Frost-Lunn is online now
Old 30-07-2008   #7
Trader Rating: (0)
Re: warning light
traction control is a wheel throwing up gravel
vB code is On
Is the HAndbrake light also a warning light? fatty Cinq/Sei > Technical 9 17-05-2008 07:48
bravo dashboard light warning light spray craig1234 Bravo / Brava 1 19-02-2008 20:11
airbag warning light and the injection warning light montysporting Punto 3 17-06-2007 19:28
Engine Management Light/Temp Warning Light Fault bugalugz Punto > Technical 0 06-03-2006 21:41
Engine Management Warning Light Madness! Power Steering light Insanity! Moneypenny Punto > Technical 10 12-12-2005 21:38
