The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo > Stilo > Technical
Old 3 Weeks Ago   #1
Trader Rating: (0)
ecu problem!!!
I have a Fiat Stilo 1.2 (2002) - had the diagnostic done which said the ecu is gone. Just need to know do I need to replace just the ecu or does the immobiliser box need to be changed too. Don't want to go to dealers who have quoted £1000 so I've tried a couple of other options - either from scrap yard from exactly the same car, or having the ecu repaired through company called 'ecu testing' mentioned in this forum. Any advice will be greatly appreciated. Thanks.
mercslk350 is offline
Old 3 Weeks Ago   #2
Trader Rating: (0)
Re: ecu problem!!!
What are the symptoms of the fault. It is probably something else.
Failed ECU's are rare, but dealers spouting crap and quoting huge bills because they don't know what they are doing is quite common.
WANTED: Faulty Connect Nav+ for parts, to fix mine.
john55 is offline
Old 3 Weeks Ago   #3
Trader Rating: (0)
Re: ecu problem!!!
The car won't start, diagnostic report said error code 01 which is ecu failure.
Old 3 Weeks Ago   #4
jostheboss's Avatar
Trader Rating: (0)
Re: ecu problem!!!
Have you tried resetting it? Disconnect the battery for 10mins or so, then reconnect? Might be worth a punt!
www.carlin.co.uk
Fiat Stilo JTD 115bhp 3DR Green/Blueish! Skyroof New Goodyear Eagle F1 Rubber
jostheboss is offline
Old 3 Weeks Ago   #5
Trader Rating: (0)
Re: ecu problem!!!
Tried that - nothing! This really is a last resort and just need some advice before I go ahead with it.
Old 3 Weeks Ago   #6
Trader Rating: (0)
Netherlands
Re: ecu problem!!!
an ecu from the scrapyard is waisted money, it won't work because it is matched to the body-computer in the car it came from - once it is connected to a car it can't be used for another one....
yellowstilo is offline
Old 3 Weeks Ago   #7
Trader Rating: (0)
Davren has donated! United Kingdom
Re: ecu problem!!!
Try disconnecting and reconnecting the plug(s) on the ECU.
I agree with John above. The actual ECU is seldom the problem. I knew someone who worked for Lucas reconditioning various ECUs. He said that 90% of the old units they got back as faulty, had nothing wrong with them.
The theory was that it was either a static charge in the wiring or a poor connection in the ECU connector. Both of which were cured by disconnecting and reconnecting the plug(s).
Dave.
Davren is offline
Old 3 Weeks Ago   #8
Trader Rating: (0)
Re: ecu problem!!!
Thanks mate. I've sent the ecu off to the 'ecu testing' place - they said they'll let me know if there is a fault, so waiting for the phone call.
Old 3 Weeks Ago   #9
Trader Rating: (0)
Re: ecu problem!!!
What if I change the ecu and the body computer (both rfom the same make and model)- will this work????
Old 3 Weeks Ago   #10
It's about GO! not SHOW!
Argonought's Avatar
Trader Rating: (0)
Argonought has donated! United Kingdom
Re: ecu problem!!!
The ECU and body computer might be OK but nothing else will work
In other words you'd be even worse off
Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic
Argonought is offline
Old 3 Weeks Ago   #11
Trader Rating: (0)
Re: ecu problem!!!
Thanks mate for the advice - I won't be doing that then!
Old 3 Weeks Ago   #12
Trader Rating: (0)
Re: ecu problem!!!
Just a thought. Have you tried the clean D4 connector guide?
john55 is offline
Old 2 Weeks Ago   #13
Trader Rating: (0)
Re: ecu problem!!!
What is that????
Old 2 Weeks Ago   #14
minimad99's Avatar
Trader Rating: (0)
minimad99 has donated! United Kingdom
Re: ecu problem!!!
3 Door Sprint Blue JTD with Skyroof, 17 inch Fox R1 alloys,-30mm Eibach Springs, Boge Turbo shocks, OMP Strutbrace, Mattig Badgeless Grill, RED.DOT Grooved brake discs and pads
RED.DOT RACING TUNED - to153BHP/201FTLB TORQUE
minimad99 is offline
vB code is On
ecu problem kennybird Punto > Technical 9 02-06-2008 13:24
ECU problem? jerhawk Bravo / Brava 3 08-05-2008 15:13
mpi sei ecu problem? / remap time? / Virgin Ecu? ronnieronson Cinq/Sei > Technical 20 10-02-2008 14:15
im sure you've had this before but ECU PROBLEM! swintonblade Punto > Technical 3 20-09-2006 22:09
ECU problem ? ndroz2003 Uno 2 10-03-2005 03:56
