| Loud Clicking Noise when changing gear :( Hi all, Have had my Stilo Abarth selespeed for about 4 weeks now, all was going well. I went to Italy on Wednesday and came back late Sunday and found my battery was dead, we jump started it and it was fine. Next morning battery dead again but that was just because I hadn't driven enough the night before to charge it. Called the AA, they came quickly and jump started it again and check the battery was ok and there was no drain in the electrics. All was fine, I drove around for about an hour and the battery is charged back up. Later in the evening I drive somewhere and all of a sudden a loud clicking noise starts. This is when the car is stationary or when it is changing gear so it seems to be when the car is in neutral that it occurs. Any ideas what the problem may be? Clutch or something? Not good ![]() Thanks for you help. Stephen
| Re: Loud Clicking Noise when changing gear :( there has always been some sort of click on my 1.2 and its something on the gas pedal. will try and hunt the post for you it does it when you come off gas
__________________ | |||
| | #3 | ||
| Brain freeze | Re: Loud Clicking Noise when changing gear :( Aux drive belt tensioner bearings perhaps. The fact that your battery is discharging could mean that the alternator is not spinning. The Aux belt is not a toothed belt, its a grooved belt. If the tesioner is slightly loose or seizing, then it could skip the alternator pulley. This could be making the slapping noise and would explain the battery issue. I could be totally wrong, but just another avenue to inspect.
__________________ Stilo JTD 115 3dr Dynamic 2002 with Skyroof, 16" Alloys, in Pitti Blue. No mods........yet | ||
| Loud clicking noise! | capers626 | Uno > Technical | 8 | 2 Weeks Ago 07:44 |
| squeling and moaning noise when revving or changing gear | xnatty19x | Punto | 8 | 08-07-2008 01:04 |
| bump noise when changing gear | swedenora | Marea > Technical | 2 | 14-07-2006 12:01 |
| Clicking noise | dg63 | Tipo | 2 | 16-05-2005 19:39 |
| Selespeed "Klonk"ing noise when changing gear | Johny | Stilo > Technical | 7 | 21-04-2005 13:08 |
