| Gearbox Centering? All- noticed our Stilo's Gearlever seems to have stopped 'centering' - i.e. does not sit in the 3rd/4th plane? You have to manually move from the 2nd across to the 3rd gear plane and from 4th to the 5th? Any ideas what could be causing and cures?
| | #2 | |||
| 5 pots rule!! | Re: Gearbox Centering?
__________________ Previous Car : 2002 Mk2 Punto Active Sport in Broom Yellow Everday Car : 1999 Mk1 Punto Sporting in Silver Weekend Toy : Stilo Schumacher GP | |||
| | #3 | ||
| | #4 | ||
| Re: Gearbox Centering? Anyone?????? I have a feeling its cable related - can you access the cabling from inside the car under the gearstick? Day off tomorrow so gonna have a check if anyone can shed some light before then - appreciated
| | #6 | ||
| Re: Gearbox Centering? Can't see any kind of selector 'spring' listed on ePer? Anyone?!!! Getting to the point where the Mrs does not want to drive it. Clutch and gears select fine its just affecting the movement between 2/3 and 4/5 and on downchanges.............
| | #7 | ||
| Whaddya mean too old? | Re: Gearbox Centering?
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX Last edited by Deckchair5; 13-09-2008 at 09:10. | ||
| | #8 | ||
| Re: Gearbox Centering? Hi Deckchair - cheers for the info - Yes taken the shift off but you can't see anything really - the ball-socket looks free enough? Have lubricated already - must be something underneath that pulls the lever across the box?
| | #9 | ||
| Whaddya mean too old? | Re: Gearbox Centering? Have a look here. A few people with the same problem http://www.fiatforum.com/marea-techn...ear-stick.html It's in the Marea section but relates to a Stilo too
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX Last edited by Deckchair5; 14-09-2008 at 08:29. | ||
| | #10 | ||
| Re: Gearbox Centering- FIXED! Sorted! Thanks all especially Deckchair. Another forum result. Actually found some info on the Stilosport forum too. The problem is actually at the gearbox end. The cables there sit in a pivot plate that is prone to sticking due to build-up of dirt. A bit tricky to get access too - I'm sure battery removal would help but get your hand in there - skin your knuckles - and give it a good turn or three. Lubricate freely with WD40 on the pivot bolt - apparently these can seize too - FIAT replacement kit available and at the two cables where they sit with rubber boots. Job done!..... Apparently its a common issue on 1.8 Stilos and HGT Puntos which use the same box. Lubricate at numbers 2,5 & 6
| | #12 | ||
| Re: Gearbox Centering? The gearlever on my 3 door JTD stopped self-centring about 2 weeks ago. The car’s done about 67000 miles. I haven’t used the car for about a week since I was told by a tyre fitting centre that a suspension spring was snapped. My car is now at the dealer to have the springs replaced and I asked if sorting the gearlever self-centring would be an expensive repair. I have been told that it needs a “gear linkage unit” which will cost £142 + VAT + (at present) an unknown amount for labour as the dealer says they have not fitted one before. The Fiat dealer charges £58 + VAT per hour for labour, so I think I’ll drive it carefully when I get the car back and take it to a nearby independent with a print out of this thread and ask him to have a look at it. If anyone has any other tips regarding what could be the problem I’d be grateful for your advice…..
| | #13 | |||||
| | #14 | ||
| Re: Gearbox Centering? If its not as efficient when hot then its probably because the wd40 is burning off, you will need to take it apart and regrease it with some high temp grease to make sure its ok and doesnt wear out.
__________________ www.carlin.co.uk Fiat Stilo JTD 115bhp 3DR Green/Blueish! Skyroof | |||
| | #15 | ||
| popping out | Re: Gearbox Centering?
| Centering steering wheel | niklasthedolphin | Car Care | 2 | 18-05-2007 23:19 |
| gearbox | dig5438 | Newbie Central | 2 | 06-04-2007 22:27 |
| Self centering | Giacosa | Panda (Classic) | 12 | 12-07-2006 00:04 |
| | smold | Bravo / Brava | 1 | 13-05-2004 19:27 |
| Gearbox | smold | Lets Talk FIAT | 0 | 12-05-2004 15:59 |
