| Mystery Bulb Changing a few bulbs on the car today, and the center one on the rear cluster has blown. No warnings coming up and I cant seem to identify it. I think its pair on the other side has blown as well. This making it even harder to find out what it does. Can anyone help? http://www.flickr.com/photos/24594070@N03/2685748150/
__________________ Nowimboard, known for his thread killing skills | |||
| Re: Mystery Bulb I think thats the side light. You have two on the rear of stilos, one is a double bulb, which is your stop and side, and then that one which is just the side light. My 5 door has a different design of light obviously, but it has two side lights on either too (as does the front). One of mine went, but i didnt get a warning on the dash, im asuming it comes on when the main side light goes (the stop and side) Replace them and see if they come on with your side lights.
| | #3 | ||
| Re: Mystery Bulb That would probably be the most simplest answer! I've got one side light per cluster working, if you think that there should be two then the blown bulbs are probably the other side light. Once I've replaced these two, I have the mammoth task of changing the front headlights/fog lights! Unfortunately I don't know any midgets or people with small hands ![]() Thanks for the help 16v!
| | #4 | ||
| Re: Mystery Bulb they are sidelights on the three door- be warned halfords list is printed wrong so take the bulb in with you to make sure you get a match
__________________ | |||
| | #5 | ||
| Re: Mystery Bulb
__________________ STILO 1.8 Dynamic 2003 ![]() Eibachs Springs -30mm, Rebadged, 7" Touchscreen, Black Out Blinds | |||
| | #6 | ||
| Re: Mystery Bulb i was seriously pised off when it happened with the front headlight as i had dismantled most of the engine bay and battery compartment to get to it. luckily i have two cars so i could drive there to shout at them.
| | #7 | |||
| Re: Mystery Bulb
Honestly! they certainly try to make things difficult!
__________________ Nowimboard, known for his thread killing skills | ||||
| Mystery Reservoir | regandavies | Panda (New) | 3 | 13-09-2007 11:35 |
| | Stickman | Cinquecento / Seicento | 4 | 20-06-2007 18:05 |
| Mystery Wire | Mr Mac | Barchetta | 10 | 10-05-2007 14:07 |
| mystery cinq! | alainax | Members Motors | 11 | 07-12-2005 22:02 |
| help solve a mystery | 69mouse | Spider | 2 | 28-08-2005 23:31 |
