| performancestilo.co.uk | the bottom end is going!!1 as above really. ![]() noticed a noise coming from the engine last week that got extremely worse in a very short time. had to be trailered to a garage as it turns over but there is no go at all. they haven't looked inside the engine but from the noise and the symptoms they have stated the bottom end is seriously about to go. likely items that would need to be replace are crank & case, pistons etc. also known as short motor?? so any ideas where i should go from here. i havent got the £1300+ to just get it reconditioned so i think my options are break up for spares or try and get what i can for it as is. ![]() unless anyone knows where there is an engine for sale? | ||
| It's about GO! not SHOW! | Re: the bottom end is going!!1
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | ||
| | #3 | |||
| performancestilo.co.uk | Re: the bottom end is going!!1 the likely culprits are lack of oil due to blocked pipe or the tinkering (remap, induction etc.) Last edited by stilosporting; 17-07-2008 at 20:19. | |||
| | #4 | ||
| It's about GO! not SHOW! | Re: the bottom end is going!!1 I'd imagine it's an oil issue as I gather the motor is pretty much thought to be unbreakable ![]() For a motor that's supposed to have such poor handling (from press reviews) it's surprising you don't see a lot more written off ![]() The truth I guess is that they don't leave the road that easily ![]() Just keep looking Frank - it's a lot of dosh to lose otherwize.
| | #5 | ||
| performancestilo.co.uk | Re: the bottom end is going!!1 my main issue is i have no car right now and need one it was castrol edge diesel oil that was in it. i would like to say it was oil starvation but as you say they are normally indestructible. i cant help but wonder had i stayed standard would i be in this position? Last edited by stilosporting; 17-07-2008 at 20:36. | ||
| | #6 | ||
| oh me gums! | Re: the bottom end is going!!1 alfa bottom ends compatible? is this the same as used in the CDTI vauxhalls?
__________________ need to contact a mod? click me _need to contact admin? click me_FAQ's_ Guides_events_everyone join this ![]() Want +20BHP for £2? Last edited by custard; 17-07-2008 at 20:49. | ||
| | #7 | |||
how certain are you of this? i checked the internals part numbers against the punto mk2 engine and they are the same but couldnt confirm the crank case was. if they are then that widens my search and increases my chances. | |||
| | #8 | ||
| Re: the bottom end is going!!1 isnt this the second engine your cars had?
__________________ | |||
| | #9 | |||
but hopefully someone will confirmthough i doubt theres great differences accross blocks in shared engine platforms? if you could confirm a VX it would really open your search
__________________ need to contact a mod? click me _need to contact admin? click me_FAQ's_ Guides_events_everyone join this ![]() Want +20BHP for £2? Last edited by custard; 17-07-2008 at 21:07. | |||
| | #10 | ||
| performancestilo.co.uk | Re: the bottom end is going!!1 yep the first was the turbo collapsing while driving after 7k miles. and now less than 60k miles. so is for different reasons but same outcome. ![]() first time was under warranty but sadly even though the car is 3 years and one month old, the 60k miles means this time its coming out of my pocket. | ||
| | #11 | |||
| | #12 | ||
| oh me gums! | Re: the bottom end is going!!1 full engine swap possible? | ||
| | #13 | ||
| Re: the bottom end is going!!1 cheap bodge and get shut?
| | #14 | ||
| performancestilo.co.uk | Re: the bottom end is going!!1 | ||
| | #15 | ||
| Re: the bottom end is going!!1 can you not get it running long enough to trade in and bite the dealers hadn off? my cousin did it with a corsa with a failed head gasket, car was smoking like a steam train and wouldnt run longer than 10/15min beofe having to cool it and top it up and start again. Made sure it was polished and a big ford dealer gave him £1500 for an x reg corsa
| | Welsh Jon | Punto | 5 | 03-04-2008 23:12 |
| Bottom end questions | Welsh Jon | Lets Talk FIAT | 5 | 31-03-2008 18:19 |
| The (bottom) END??? | jonti | Tipo | 8 | 16-05-2007 13:30 |
| Has my bottom end gone?? | jonti | Tipo | 18 | 24-11-2006 23:21 |
| | CaneyJ | Cinquecento / Seicento | 15 | 31-05-2006 21:31 |
