The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 24-06-2008   #1
Trader Rating: (0)
1.2 Engine Fault and jolt to car
Ive had my 1.2 16v active stilo for 3 years in november. Last year it came up with engine fault and the car jerked forward whilst driving and if i was idling at a junction or traffic lights it just switchs off. The computer was replaced in november and it ran fine until about a month ago and its started again.. on friday it cut out as i was driving along at 30. The screen goes all funny and asr failure, loose connection, low oil pressure lights come up. But it has had a new oil filter on.
My dad had a look on sunday pulled out every wire possible sprayed the connections with wd40 and re attached them also cleaned the spark plugs and tightend the connections.
Now touch wood ive drove to work yesterday and today fine without an issue. Can this really of solved the issue or is ther something else underlying?
Any help greatly appreciated!
cricketchick_23 is offline
Old 24-06-2008   #2
Trader Rating: (0)
re: 1.2 Engine Fault and jolt to car
hey am new how do i send 1 of these forums
stevn sporting is offline
Old 24-06-2008   #3
Trader Rating: (0)
you just click on new thread and away u go lol
Old 24-06-2008   #4
Shropshire UK
Ffoxy's Avatar
Trader Rating: (0)
Ffoxy has donated! United Kingdom
Did he also check the battery terminals?
Ex Suzuki SV1000S jockey, now just me and my 1.9 MJet Grande Punto Sporting in New Orleans Blue. 193.8 Bhp and 261ft lbs torque.
Ffoxy is online now
Old 24-06-2008   #5
Trader Rating: (0)
I would imagine so... if it had a wire he could pull out he will off done. Do you think it could be a battery issue?
Old 24-06-2008   #6
Shropshire UK
Ffoxy's Avatar
Trader Rating: (0)
Its possible and easy to check, was an issue on Punto models, as were dodgy earths causing oddball faults intermittently. Clean the terminals and reconnect them securely, adding some petroleum jelly. NOT grease. Ditto the earth points. Its a start.
Ffoxy is online now
Old 28-06-2008   #7
Trader Rating: (0)
ok tried that and its not worked...... its doing the engine fault more than ever now
Old 28-06-2008   #8
Grumpy Forum Moderator
T14086's Avatar
Trader Rating: (0)
T14086 has donated! United Kingdom
has he checked the main earths (especially on gearbox) common fault.
T14086 is offline
Old 28-06-2008   #9
Trader Rating: (0)
not sure il get him to look at that in the morning... it seems to be when it gets to temperature it starts.
it ran ok monday - thurs after he played on sunday started having a bit of a fit thurs so he did the battery thing then its worse than ever friday and today.
Old 29-06-2008   #10
minimad99's Avatar
Trader Rating: (0)
minimad99 has donated! United Kingdom
Does the 1.2 have a crank sensor?
Symtoms seem to match those on my JTD when the crank sensor went up te shoot.
3 Door Sprint Blue JTD with Skyroof, 17 inch Fox R1 alloys,-30mm Eibach Springs, Boge Turbo shocks, OMP Strutbrace, Mattig Badgeless Grill, RED.DOT Grooved brake discs and pads
RED.DOT RACING TUNED - to153BHP/201FTLB TORQUE
minimad99 is offline
The following user says "Thank You!" to minimad99 for this useful post:
cricketchick_23 (14-07-2008)
Old 29-06-2008   #11
T14086's Avatar
Trader Rating: (0)
yep
T14086 is offline
Old 29-06-2008   #12
Whaddya mean too old?
Deckchair5's Avatar
Trader Rating: (0)
Deckchair5 has donated! United Kingdom
I'd go for the main battery earths. The crank sensor (rpm sensor) wouldnt cause the ASR warnings. Also, when the engine stops with an rpm sensor fault, it doesn't start again until it feels like it.
Your low oil pressure warning comes up because it IS low oil pressure when the engine stalls away so that's normal to see that flick up
The 1.2 engine is a fantastically reliable unit, mine's 9 years old now and on 110k miles but just flew through it's MOT this week and the emissions were as clean as they were when it was new- green lights all the way. Still runs as well too. It's gonna go on for ever
Undo the earth lead and clean up the contact point where it attaches to the gearbox, renew the lead if you're in any doubt
Check the voltage drop- one lead on the earth at the battery and put the other lead actually on a good contact on the gearbox (not on the other end of the lead) and see if there's any voltage being registered. Should be near to zero of course showing no electrical resistance between the battery earth line and the engine, anything more than 0.5v and there's your problem
02 Stilo 1.6 Dynamic 3 door
99 Bravo 1.2SX
Deckchair5 is offline
Old 30-06-2008   #13
Trader Rating: (0)
ok tried all this and somehow seems worse unless its just my imagination i think im just getting fed up of the issues now! ran perfect this morning then tonight didnt wanna know wouldnt idle at the traffic lights and kept jolting when it felt like it..... strange thing is wen the oil light appeared after the engine fault and jolt if u revved as u were driving it wouldnt cut out and set of going again
Old 30-06-2008   #14
T14086's Avatar
Trader Rating: (0)
think it might be time for garage to take a look at it?
T14086 is offline
Old 30-06-2008   #15
Trader Rating: (0)
i think it is some sort of connection issue everytime he plays it drives better for a few days then goes again!
dont really want to take it to fiat and get charged 70quid for diagnostics and then god knows wat on top of that!
Im only driving it till i get me new car its due next week... not long now!!!!
(T) Engine fault/sensor fault JTD bozzy Stilo 39 15-07-2007 23:03
(T) Engine fault light comin on and off and car shaking on starting up. . treacle1 Punto 2 29-11-2006 16:50
(T) Engine fault/Security fault StiloJoe Stilo 8 11-02-2005 00:16
