The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 21-06-2008   #1
Trader Rating: (0)
Skywindow won't shut
My Skywindow won't shut. My mechanic believes the fault has to do with the curtain. Anyone come across this one before?
Cheers,
Steve
Stilo MW JTD Dynamic 115,
hywyn is offline
Old 21-06-2008   #2
Grumpy Forum Moderator
T14086's Avatar
Trader Rating: (0)
T14086 has donated! United Kingdom
Re: Skywindow won't shut
yes well detailed here..search for answer.
T14086 is offline
Old 21-06-2008   #3
Trader Rating: (0)
Thanks but I already tried that. Searches reveal others that have had a similar problem but no fixes other than a button to reset the sky roof.
When it first became a problem (on a family holiday in the rain) I eventually managed to shut the sky roof and took out the fuses. That's how it has remained until the other day when my mechanic had a further look. Although it continued to fox him he deduced that the problem is with the curtain. He didn't have the time to investigate any farther and took the fuses out again and after several attempts at shutting the sky roof!
Cheers,
Steve
hywyn is offline
Old 21-06-2008   #4
T14086's Avatar
Trader Rating: (0)
unlikely to be the curtain, does it actually open? what exactly is the fault?
T14086 is offline
Old 21-06-2008   #5
Trader Rating: (0)
When attempting to shut the sky roof it will go one stage forward and then two back until eventually it won't budge.
My mechanic detected an electrical spark / charge from the curtain fuse, nothing more diagnostic than that, although he had spent some time on it.
Steve
hywyn is offline
Old 21-06-2008   #6
T14086's Avatar
Trader Rating: (0)
resistance on the glass causes this, the motor senses this resistance & it opens the glass. Try lubricating the runners first, cheapest & easiest things first
T14086 is offline
Old 21-06-2008   #7
Trader Rating: (0)
Thanks! Is WD40 ok for this?
Steve
hywyn is offline
Old 21-06-2008   #8
T14086's Avatar
Trader Rating: (0)
Steve
silicon based grease/spray would be better.
http://www.fiatforum.com/stilo-techn...need-help.html
T14086 is offline
Old 21-06-2008   #9
ABZSTILO's Avatar
Trader Rating: (0)
ABZSTILO has donated! United Kingdom
Wink Re: Skywindow won't shut
'03 JTD Dynamic Grigio Steel with skyroof, Eibach -30mm prokit, Abarth shadow chrome 16" alloys with Vredestein Sportrac 3 tyres, OMP strutbrace.
ABZSTILO is offline
Old 21-06-2008   #10
It's about GO! not SHOW!
Argonought's Avatar
Trader Rating: (0)
Argonought has donated! United Kingdom
Excellent guide above
..and here's even more info
You seriously need to clean the sky-roof fairly frequently because if you don't you'll lose it
Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic
Argonought is offline
Old 21-06-2008   #11
Trader Rating: (0)
Many thanks people!!!
Steve
hywyn is offline
Old 22-06-2008   #12
ABZSTILO's Avatar
Trader Rating: (0)
Thumbs up Re: Skywindow won't shut
Steve
Glad to help Steve - hit the thanks button, we all appreciate it
ABZSTILO is offline
The following user says "Thank You!" to ABZSTILO for this useful post:
Most Easterly Pandas (22-06-2008)
Old 22-06-2008   #13
Panda's with Gadget's
Most Easterly Pandas's Avatar
Trader Rating: (0)
Most Easterly Pandas has donated! United Kingdom
Just for you ABZSTILO, I found your help useful, even though I don't have a Stilo.
Jon.
Most Easterly Panda's - Panda'ing in East Anglia
5 Panda's! 1989 F-reg 750L, 1991/1992 (not sure as on a NI plate) Panda 1000CL,
1993 K-reg Selecta (1108cc) x2! 1988 E-reg Sisley 4x4
Originally Posted by Jai View Post
grip the meat, loosen the throat, relax and slide it in
If my post or someone else's has helped, say thank you using the Thanks Button \/
Most Easterly Pandas is offline
Old 22-06-2008   #14
ABZSTILO's Avatar
Trader Rating: (0)
Jon.
ABZSTILO is offline
(G) Skywindow - help gorole Stilo 2 13-04-2008 09:29
(G) Seized skywindow billabong Stilo 10 12-08-2007 13:43
(T) Skywindow woes hywyn Stilo 12 21-07-2007 12:04
(G) help needed with skywindow rustycoupling Stilo 9 16-04-2007 13:21
(T) SkyWindow zzdeb Stilo 21 17-02-2004 07:30
