The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo > Stilo > Technical
Old 19-06-2008   #1
NobodyBlamesTheHappyGuy:D
Morty Mort's Avatar
Trader Rating: (1)
Morty Mort has donated! Norway
Tyre brand experiece.
It is a resurrecting question, but what a bout a thread that discuss tyre quality and choice of tires, and not uneven wear and tear due to the Stilo's suspension setup.
You usually get what you pay for, but high quality tires tend to wear faster - but grip better. Different driving conditions and climatic differences are factors which can make any tyre test seem way out. A great tire in Japan will most likely be a stupid choice for a Norwegian road. Factors as how much tar there are in the asphalt, wintertires with spikes that roughen the surface, and leaves that fall in autumn have to be taken into consideration. And in addition loads of water might pour from the sky at no time.
The greatest tire I've ever been on is the Good Year Ventura, which is out of production now. This really satisfied everyting from extreme great grip in superwet conditions and in addition sucked itself to low quality asphalt in high speed driving and hard cornering. It didn't wear much either. If I could come over a set of these wouldn't hesitate at all.
Now I am on Pirelli P7000 which is very good in dry conditions, but I am not all satisfied with grip in wet conditions. I slip and slide a bit. It seems like a tough tyre though.
Over to my tyre question. Has anyone any experience with this tyre?
http://ssl.delti.com/cgi-bin/reifenb...105591&dsco=29
It's a Nokain, Finnish made for North-European conditions.
What's your tyre experience?
Morten.
jet blue. 17" blades. eibach pro system. omp bar. gsr breath. mattig face. debadged. phoenix gold watts. rear tint.
member of the 5-door massive attack.
Morty Mort is offline
Old 19-06-2008   #2
Trader Rating: (0)
Re: Tyre brand experiece.
Hi Morten - I'm not an expert but would advise you do fiatforum search using search terms [Nokian] and [UTQG] & that will take you to threads in Punto section & Grande Punto section. Have a look at the Which? tests & German ADAC tests.
The Nokian NRY has a 280 UTQG rating.
Caravadossi is offline
Old 19-06-2008   #3
Morty Mort's Avatar
Trader Rating: (1)
Yeah your right, but the reason I asked i the Stilo section is because I don't think the same tire matches every car, despite many of the Fiats have similiar suspension setup. So a tyre choise for the Stilo.
M.
Old 19-06-2008   #4
Trader Rating: (0)
I understand Mort - & also different sizes will show different rankings in the tests.
Try a Google search using [reifentest +Stilo] & this will give you test results specific to the Stilo.
Old 19-06-2008   #5
Shropshire UK
Ffoxy's Avatar
Trader Rating: (0)
Ffoxy has donated! United Kingdom
Take a look at Sumo Firenzas, £50 a corner fitted for my 1.9 GPS and I have to say they are better in every way than the Bridgestone OE tyres.
Ex Suzuki SV1000S jockey, now just me and my 1.9 MJet Grande Punto Sporting in New Orleans Blue. 193.8 Bhp and 261ft lbs torque.
Ffoxy is offline
Old 19-06-2008   #6
Trader Rating: (0)
Muppet1 has donated! United Kingdom
Well i have ask this very same question here;
http://www.fiatforum.com/stilo/15079...oy-wheels.html
Now at the moment i have Hankook Optimo K415 195/60/15 on the front and they are very good in the dry and good in the wet, However the cheap rubbish called Mohawk on the back are hopeless and they got changed on the front way way before they was even half worn as they was RUBBISH period.
Now im probibly going to have hankooks on my new alloys in a few weeks as i like the brand and have used them for about 8 years, or i might try those on ebay. Havent really decided yet but will keep everyone informed.
Muppet1 is offline
Old 19-06-2008   #7
Stilatos's Avatar
Trader Rating: (0)
Greece
ill give some experience i have with tires in greece. The factory tires that came with if i remember were pirelli 5,000 i think anyways there were ok for the first 10,000 klm but the grip turned bad and the asr kept lighting up every time i pulled of into a street and were horrible. i put eagle f1s that completely changed the car. \\THe ride is a bit harder but the grip is way better now. THe only trouble is that in the winter they need some time to warm up or they act like a typical normal tire than the sports tire they are designed for. But when those suckers warm up good they are almost like glue. The tire even though is sports oriented does give you a level of warning when their reaching their grip threshhold (slightly losing grip and screeching) so you can tell.(usually racing tires give you very little warning and you just lose grip all of a sudden)
Mind you i have a 1.6 maybe you big boys with the 2.4 liter shouldnt have such a big problem. Engine size does play a role cause you can warm your tires up more if there is more force exerted on the tires during acceleration (were not talking burnouts).
In the wet they are pretty good not anything crazy but i do find it to be able to take corners or raise my comfort level of speed in the rain by 20 klm. Tire wear the first time was a big issue since i fell in love with them and was taking every corner like i was schumacher so they lasted me only 18,000 klm. THe second and third pair i have on lasted me a bit more about 27,000 klm. I do want to try a different tire though but i dunno if i should since i got so comfortable with these and know their limits well. I was thinking of contisports 2 since alot of guys in the club liked them. Unless goodyear releases the new eagle f1s in my tire size of 205/55/16 if im mistaken their smallest tire is a 17 inch.
1.6 silver dynamic 3d with skywindow, Schumacher Look, Abarth Pedals,Brembo Brakes,Bilstein Eibach Suspension, Eagle F1 Tires, K&N Filter,Sport Steering Wheel,Sport Knob,3M tint.Philips New Vision Lights. Founder & Admin of the Greek Stilo club www.stiloclub.gr
Stilatos is offline
The following user says "Thank You!" to Stilatos for this useful post:
Morty Mort (20-06-2008)
Old 20-06-2008   #8
Morty Mort's Avatar
Trader Rating: (1)
Thank you for this useful post.
Originally Posted by Stilatos View Post
ill give some experience i have with tires in greece. The factory tires that came with if i remember were pirelli 5,000 i think anyways there were ok for the first 10,000 klm but the grip turned bad and the asr kept lighting up every time i pulled of into a street and were horrible. i put eagle f1s that completely changed the car. THe ride is a bit harder but the grip is way better now. THe only trouble is that in the winter they need some time to warm up or they act like a typical normal tire than the sports tire they are designed for. But when those suckers warm up good they are almost like glue. The tire even though is sports oriented does give you a level of warning when their reaching their grip threshhold (slightly losing grip and screeching) so you can tell.(usually racing tires give you very little warning and you just lose grip all of a sudden).
In Norway, cars come with two sets of wheels - one for winter, and one for summer. Tyre and alloy prices are doubled for us... We don't drive with summer tires during winter, due to grip and handling, so warm-up time is irrelevant. Most cars tend to warn their driver sometime before the accident, but as we modify the cars with strut braces, lowering springs, and other sporting equipment we don't get the warning before we are messed up with nature... But it is great though, that the tyre will tell. Anyway I've been in Glyfada for a week some years ago, and the asphalt compund is rather different than here. Driving in Glyfada and Athens really needs all your senses alert... Some of us drive on spikes during winter which roughens the asphalt aswell. And we use lesser amount of tar in the asphalt compount as far as I can remember. In other words, we don't have slick (or as hot) asphalt that will screech unless it is completely fresh.
The largest engine here is 1.8. The Abarth would become too expensive due to heavy taxing of engine volume and bhp, so i doesn't exist. I've got the 1.6 aswell, so your tire info will be most valued by me.
20-25.000 km is really good I think, especially as you drive on the same set all year around. Water is the biggest issue for me, but that seems to be alright aswell. The tire isn't that expensive here either. About 1000 NOK, which (today) equals about 100 GBP. I will need 215/45R17 as I'm on 17" on the summer wheels. Winters are 195/65R15 - but that is a completely different tire.
Regards, Morten.
Old 20-06-2008   #9
Stilatos's Avatar
Trader Rating: (0)
Greece
THe asphalt quality in greece is a bit poor i cant explain it but yes it does seeem very tary when first put, put then loses it after time revealing sometimes the coarse rock on the first layer.
Also dont forget when i mean winter weather im saying an average of 10-12 deg for glyfada greece. These tires are great but warming up is abit of an issue i will say again.
Stilatos is offline
vB code is On
Just got my brand new GP! trypanosomiasis Grande Punto 6 01-06-2008 19:35
Brand New Panda !! Starbok Panda (New) 4 09-12-2007 09:21
Recommend a cheap tyre fitted by a tyre chain? 1986Uno45S Leisure Lounge 8 30-03-2007 08:48
Tyre pressure for spare tyre Cinquelover Cinquecento / Seicento 2 19-02-2006 22:02
brand new k&n Stef_puntosx Parts for Sale 5 04-08-2004 10:58
