| Fitted new pads alround, brakes now screeching Hi, I have recently fitted new pads front and back, but since day one they screech when I pull up, it is only at slow speeds. Apart from that they work fine but it is now becoming a bit annoying (especially for cars in front of me, when I pull up at lights they hear the noise and think I have braked late and am going to hit them). I did use fairly cheap pads, do you think it may be the compound that cheaper pads use?, also I do not use any copperslip. Does anyone have any ideas or comments please? Thanks
| The modfather | Combination of cheap pads and lack of copper slip..buying cheapo brake parts is false economy.. fiat pads have a rubber backing and that helps to stop brake squeal..
| | #3 | ||
| Re: Fitted new pads alround, brakes now screeching Do you think copper slip will help, or do you think I need to replace the pads again?
| | #4 | ||
| Re: Fitted new pads alround, brakes now screeching Some copper slip and few thousand miles should get them quiet. don't forget to say ta | |||
| | #5 | ||
| Re: Fitted new pads alround, brakes now screeching Thanks guy's, I will try putting some copper slip on first and go from there.
| | #6 | ||
| Shropshire UK | Re: Fitted new pads alround, brakes now screeching
__________________ Ex Suzuki SV1000S jockey, now just me and my 1.9 MJet Grande Punto Sporting in New Orleans Blue. 193.8 Bhp and 261ft lbs torque. | ||
| | #7 | ||
| The modfather |
| | #8 | |||
| It's about GO! not SHOW! | Re: Fitted new pads alround, brakes now screeching
Is the squealing drives you made then you might be forced to go back to oem pads ![]()
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | |||
| | #9 | ||
| You can't fool owls. | Re: Fitted new pads alround, brakes now screeching Think the OP diagnosed the issue. The runners need a good wire brushing to clean any brakedust or rust off, then a good dose of copperslip on the runners and the back of the pads where they contact the caliper and piston. Make sure none goes on the disc of course! ![]()
__________________ ![]() 'Not everything in black and white makes sense' | ||
| | #10 | ||
| Lean Mean Grey Machine | Re: Fitted new pads alround, brakes now screeching I've had this in the past with previous cars. The worst offenders were Halfords own brand, followed by AP Lockheed. I've never had any issues with Ferodo Premier range and always use them. They also last fairly well. Using copper grease is always worth doing as well.
__________________ _____________________________________________ '52 Fiat Stilo JTD 115 Dynamic, 3dr, Orion Grey, Celtic Remap 165 Bhp, 17" Jet Alloys & Honda CB1300 | ||
| | #11 | ||
| Re: Fitted new pads alround, brakes now screeching I had the similar problem when i fitted new pads on older dsks. I've ignored it, and now its fine! ![]() ![]() ![]()
__________________ 1.6 16v / Skywindow / Clima / Cruise Control / CDA Air Intake Filter / Sparco Aluminum Pedals / Eibach Springs / Bilstein Yellow Shocks / HID Xenon 4300K XLS. / Cocconut Perfume![]() Ambition bites the nails of success | |||
| Has Anyone Fitted Front Brake Pads | Shepherd | Multipla | 9 | 26-07-2008 08:05 |
| Another brakes, discs and pads thread | gearfinger | Stilo | 18 | 08-02-2008 21:41 |
| New discs and pads fitted. | nuovapanda | Panda (Classic) | 3 | 16-04-2007 19:09 |
| uprated brakes or pads? | sly | Stilo > Technical | 6 | 22-04-2004 02:34 |
| Punto Brakes & pads | Hornet | Punto > Technical | 3 | 07-11-2003 19:22 |
