The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 17-06-2008   #1
Trader Rating: (0)
Germany
Odometer resets itself to 102000km
Hello guys,
after a long time a new thing happened to my Stilo:
The odometer spontaneously resets itself to 102000km. This usually goes along with a weird average fuel consumption of 25l/100km. Then the odometer counts up normally until it resets itself to 102000km again.
Any suggestions?
Best,
Lars.
5d 2002 Stilo 1.2 in stone gray, Abarth dash + Connect NAV+, a few more goodies, just ask =) nice car!
2005 Punto MkIIb 1.4 Emotion fully loaded.
larzmaster is offline
Old 17-06-2008   #2
Trader Rating: (0)
Re: Odometer resets itself to 102000km
leave it like that as it will still have that mileage when you come to sell it
WANTED: Faulty Connect Nav+ for parts, to fix mine.
john55 is online now
Old 17-06-2008   #3
Trader Rating: (0)
Germany
yeah, that was my initial thought too. still, i want it to work...
Old 17-06-2008   #4
Trader Rating: (0)
Just noticed your sig. You have an abarth dash in a 1.2. Do you mean you have abarth dials?
Generally they don't like each other. See yellostilo posts about fitting abarth dials. Does it do it on the original dials?
Old 17-06-2008   #5
Trader Rating: (0)
Netherlands
Hello Lars,
I put an Abarth instrument cluster in my 1.6L Stilo and had to fit a time delay circuit in between the switched power line to prevent "high coolant temperature" warnings and beeps during the initial start-up.
It also shows "cruise control activated" and sometimes it shows the level bar of the automatic light sensor which i don't have....
So there definately is a compatibility issue between the Abarth cluster and the 5NFt1 ecu of the 1.2 / 1.6L Stilo's....
Didn't you have any other problems after fitting your Abarth cluster?
I still haven't found the cause of these problems - I would fit the original cluster to check if the problem is solved after that - however it is a pity to remove the beautiful Abarth cluster , i agree...
Good luck finding a solution for your problem - please post here if you solved it ...
yellowstilo is offline
Old 17-06-2008   #6
Trader Rating: (0)
Germany
Well, the dash works just fine - it has been fitted to my car via proxy realignment through the examiner. That should not be the problem. I have a time delay circuit, but only for the CN+. Which unit actually calculates the mileage and trip computer settings?
BTW, I don't have the original dash anymore...
Old 17-06-2008   #7
Trader Rating: (0)
Netherlands
mileage and trip computer settings are stored in the instrument cluster.
Mileage is also stored in the engine ecu for reference.
I also did a proxy alignment procedure but i still have those compatibility issues...
I hope you will be able to solve your problem, good luck!
Old 17-06-2008   #8
It's about GO! not SHOW!
Argonought's Avatar
Trader Rating: (0)
Argonought has donated! United Kingdom
Might not be any connection in this case but quite a while ago a member or two posted this problem and it turned out to be due to a garage trying to reset the service counter without Examiner.
Just a thought
Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic
Argonought is offline
(T) odometer repair hydie331 Stilo 5 08-09-2008 09:27
(T) Odometer light Zed McJack Bravo / Brava 3 14-04-2008 10:49
(G) Odometer flashes dpr59 Grande Punto 5 23-03-2008 10:23
(T) CD Changer Resets After Power Off In Abarth kelvin Stilo 13 23-04-2007 22:37
(T) Odometer Help Anyone? Pecora Grande Punto 17 14-11-2006 14:15
