| Odometer resets itself to 102000km Hello guys, after a long time a new thing happened to my Stilo: The odometer spontaneously resets itself to 102000km. This usually goes along with a weird average fuel consumption of 25l/100km. Then the odometer counts up normally until it resets itself to 102000km again. Any suggestions? Best, Lars.
__________________ 5d 2002 Stilo 1.2 in stone gray, Abarth dash + Connect NAV+, a few more goodies, just ask =) nice car! 2005 Punto MkIIb 1.4 Emotion fully loaded. | |||
| Re: Odometer resets itself to 102000km leave it like that as it will still have that mileage when you come to sell it ![]()
__________________ WANTED: Faulty Connect Nav+ for parts, to fix mine. | |||
| | #3 | ||
| Re: Odometer resets itself to 102000km yeah, that was my initial thought too. still, i want it to work...
| | #4 | ||
| Re: Odometer resets itself to 102000km Just noticed your sig. You have an abarth dash in a 1.2. Do you mean you have abarth dials? Generally they don't like each other. See yellostilo posts about fitting abarth dials. Does it do it on the original dials?
| | #5 | ||
| Re: Odometer resets itself to 102000km Hello Lars, I put an Abarth instrument cluster in my 1.6L Stilo and had to fit a time delay circuit in between the switched power line to prevent "high coolant temperature" warnings and beeps during the initial start-up. It also shows "cruise control activated" and sometimes it shows the level bar of the automatic light sensor which i don't have.... So there definately is a compatibility issue between the Abarth cluster and the 5NFt1 ecu of the 1.2 / 1.6L Stilo's.... Didn't you have any other problems after fitting your Abarth cluster? I still haven't found the cause of these problems - I would fit the original cluster to check if the problem is solved after that - however it is a pity to remove the beautiful Abarth cluster , i agree... Good luck finding a solution for your problem - please post here if you solved it ...
| | #6 | ||
| Re: Odometer resets itself to 102000km Well, the dash works just fine - it has been fitted to my car via proxy realignment through the examiner. That should not be the problem. I have a time delay circuit, but only for the CN+. Which unit actually calculates the mileage and trip computer settings? BTW, I don't have the original dash anymore...
| | #7 | ||
| Re: Odometer resets itself to 102000km mileage and trip computer settings are stored in the instrument cluster. Mileage is also stored in the engine ecu for reference. I also did a proxy alignment procedure but i still have those compatibility issues... I hope you will be able to solve your problem, good luck!
| | #8 | ||
| It's about GO! not SHOW! | Re: Odometer resets itself to 102000km Might not be any connection in this case but quite a while ago a member or two posted this problem and it turned out to be due to a garage trying to reset the service counter without Examiner. Just a thought ![]()
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | ||
| odometer repair | hydie331 | Stilo > Technical | 5 | 3 Hours Ago 08:27 |
| Odometer light | Zed McJack | Bravo/a > Technical | 3 | 14-04-2008 09:49 |
| Odometer flashes | dpr59 | Grande Punto | 5 | 23-03-2008 09:23 |
| CD Changer Resets After Power Off In Abarth | kelvin | Stilo > Technical | 13 | 23-04-2007 21:37 |
| Odometer Help Anyone? | Pecora | Grande Punto > Technical | 17 | 14-11-2006 13:15 |
