The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 18-06-2008   #16
More ICE Please
volxstu's Avatar
Trader Rating: (0)
volxstu has donated! United Kingdom
Re: JTD/MJET - induction and remaps, please read!
Right i may be getting slightly out of my depth here but these are remarkably similar to the probs with N/A petrol engines without remaps.
It seems you are experiencing turbo Lag and i am experiencing flat spots at the rev ranges where the most difference from standard is made.
I can only explain this by fault of the ECU not understanding what this extra information is at this point and the advanced timing is going out of sink of the fuelling. (I dont have a clue what this means as i said before im not too up on how engines work i am just deriving from facts) anyway this could explain dirty sparks in my old Punto. One would imagin that if you are trying to ignite nothing then you would get excess carbon build up. (another thing that i just assume)
Oh and this maybe useful or just confuse matters even more. I have tried to Map my car but it ran less HP than when it was standard and it turns out that the Lambda sensor had started to go seemingly the instant the map was put on so i put it back standard as i had to have the work done on warrenty.
One more thing for my 1.6 fiat dont reackon that the Torque and HP pass at 5381 Revs or whatever it is supposed to be we disregarded this as wrong but .
Originally Posted by Tris Harris View Post
I have tried to stay on here incase anything remotely interesting popped up me...
a chocolate finger sounds good
volxstu is offline
Old 18-06-2008   #17
performancestilo.co.uk
stilosporting's Avatar
Trader Rating: (5)
stilosporting has donated! United Kingdom
Originally Posted by john55 View Post
Have you tried cleaning your inlet manifold and stop valve. It is quite a job to get the manifold off, but they really get gummed up with the EGR soot mixed with oil and the airflow is significantly restricted into the engine. I have cleaned the stop/ air cutoff valve on mine, but have not tried the manifold yet. (Mine is not remapped and I don't get error codes) but think it is something you should try. Also clean the MAP sensor at the same time.
what do you class as the stop valve?
www.reddotracing.co.uk
162.6bhp 219.8ft-lb
stilosporting is offline
Old 18-06-2008   #18
Trader Rating: (0)
The butterfly valve in the air stream, where it enters the manifold, next to the EGR inlet.
WANTED: Faulty Connect Nav+ for parts, to fix mine.
john55 is offline
Old 18-06-2008   #19
Trader Rating: (5)
throttle body?
162.6bhp 219.8ft-lb
Old 18-06-2008   #20
It's about GO! not SHOW!
Argonought's Avatar
Trader Rating: (0)
Argonought has donated! United Kingdom
Question Re: JTD/MJET - induction and remaps, please read!
So, I presume you removed it from the manifold to clean it?
Just how dirty was it?
Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic
Argonought is offline
Old 18-06-2008   #21
Trader Rating: (5)
did you guys see mine before i cleaned it?
162.6bhp 219.8ft-lb
Old 18-06-2008   #22
PNL
The modfather
PNL's Avatar
Trader Rating: (0)
PNL has donated! United Kingdom
Cool Re: JTD/MJET - induction and remaps, please read!
I did ..
PNL is online now
Old 18-06-2008   #23
Trader Rating: (0)
i have a 2005 1.9 jtd doblo tht has been angel tuned but no induction kit!
had a engine management light issue turned out it was a fault code that didnt save in the memory! so went after 4/5 ign cycles and went out, only made the light come on when you were being a little enthusiastic at the top end of the rev range in 4th norm whilst overtakin ppl :P
on the next service i found it to be the small hose from the back of the turbo to the boost controller assembly had come loose reconnected all is good,
the only downside is it doesnt make max power when its really hot outside i think the standard intercooler struggles in hotter weather to lower ambient charge temp, overall very pleased with the tuning in general wouldnt change back i luv the extra power and torque,
i couldnt recommend angel any more highly!! superb service!
derbydoblo is offline
Old 18-06-2008   #24
Trader Rating: (0)
Yes I did and very dirty. Probably 20% reduced in size due to crud build up inside. I imagine the rest of the manifold is the same. One day, when I have time, I'll take it off too.
john55 is offline
Old 18-06-2008   #25
Trader Rating: (0)
throttle body?
No. Only petrol engines have a throttle body.
john55 is offline
Old 18-06-2008   #26
ABZSTILO's Avatar
Trader Rating: (0)
ABZSTILO has donated! United Kingdom
No, not turbo lag. What some of us are getting is effectively a turbo 'shut down' as the ECU goes "what the feck" a situation which I'm trying to either do away with or bypass.....
I'm still to be convinced it's the ECU..... I strongly believe the sensors are the key. The ECU simply responds to the signals it gets sent.... so cheat the signals and you have a sort of solution.
'03 JTD Dynamic Grigio Steel with skyroof, Eibach -30mm prokit, Abarth shadow chrome 16" alloys with Vredestein Sportrac 3 tyres, OMP strutbrace.
ABZSTILO is offline
Old 18-06-2008   #27
Argonought's Avatar
Trader Rating: (0)
Surely the only relevant sensor is the MAF (and not forgetting temperature )
I'm a bit confused by this thread already?
Do Red Dot remaps without GSR induction still produce engine faults anyway? (Minimad seems to suggest they do )
Old 18-06-2008   #28
Trader Rating: (5)
maf, map, overboost valve, boost pressure sensor?
What controls the veins on the turbo?
162.6bhp 219.8ft-lb
Old 18-06-2008   #29
popping out
dan-the-man's Avatar
Trader Rating: (0)
dan-the-man has donated! United Kingdom
Unijet JTD ChippedUK remap - No Faults
dan-the-man is offline
Old 18-06-2008   #30
Argonought's Avatar
Trader Rating: (0)
Yes; but MAP is post turbo - so a bit indirect from induction
(T) ecu remaps! Lawrence_16 Stilo 2 09-01-2008 22:32
(G) Is Your JTD diesel engine smoking under normal revs- You need to read this. javednazeer Marea 3 08-04-2007 22:02
(T) petrol engine remaps? deod182 Grande Punto 9 16-03-2007 18:51
(T) remaps arc Cinquecento / Seicento 8 09-05-2004 07:50
