| | #16 | |||
| It's about GO! not SHOW! | Re: Tyre Pressures
![]() Obviously, there comes a point when the increased grip you get from low tyre pressures is negated and in any case it's a really bad idea to go outside tyre manufacturers recommendations (they should know):
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | |||
| | #17 | ||
| Re: Tyre Pressures mine are at 29 psi all round, im on 15 inch steelies, book said would be ok, will possibly top up now
__________________ | |||
| | #18 | |||
| Re: Tyre Pressures I find it quite scary the number of cars you see around with obviously soft tyres with the sidewalls rubbed away as a result. Tyres are things which need to be taken care of, checked often for cuts and damage and pressure - which should be run at or around recommended pressures. I was nearly involved in a big accident on a motorway not so long ago, as a result of a driver not taking care of his tyres, and being numb enough not to realise he had a totally flat rear tyre at 90mph. That was the end of his car and crash barrier, along with a couple of passing cars too. I just narrowly avoided it, as it all happened a few metres infront of me. So it pays to know your tyres are in their best condition, at all times! ![]()
You need to get a happy compromise dont you, too low and you will scrub off the edges in no time, more heat will be built up which increases the chance of a blow out, steering will be more vague, grip could also be effected as the tyre is rolling over onto its sidewall and its making extra drag. Too much can cause a hard ride, wear to the centre of the tyre, more likely to damage an over inflated tyre front driving up/against curbs (although just as easy with underinflation), blow outs can also be common, as when the tyre heats up, it will be at an even greater pressure. So all im saying, is tyres are not to be played with, they need care ![]()
__________________ 52 Fiat Stilo 1.6 Active - Fire engine red! | ||||
| | #19 | ||
| Dislikeskeyboardwarriors | Re: Tyre Pressures i always prefer to run tyres harder, the old allys i had, 225/40/18"s were running 38-39psi and tread wear was perfect, these were 8j rims,, the new alloys with new rubber seem to run best about 37psi all round, blow outs scare me, and you're far more likely to have a blow out with an under inflated tyre than one running harder,
| | #20 | |||
| Re: Tyre Pressures
Id opt for over rather than underinflated as its safer, although the correct pressure is best obviously. Ive upped my Stilos pressures today, to 35 front and 33 rear, so ill see how i get on!
| | #21 | ||
| Re: Tyre Pressures For those of us with tyre pressure gauges that read in bars this thread is a little pointless unless somebody posts a conversion table .
__________________ Stilo | |||
| | #22 | ||
| Re: Tyre Pressures Bar makes no sense to me I always work in PSI ![]() This: http://www.centauro-owners.com/articles/psibar.html should help. 1 bar is roughly 15PSI.
| | #23 | ||
| Re: Tyre Pressures checked mine and i have a piece of metal in one. great stuff
| | #24 | ||
| | #25 | ||
| Re: Tyre Pressures Dont do it!!
__________________ www.carlin.co.uk Fiat Stilo JTD 115bhp 3DR Green/Blueish! Skyroof | |||
| | #26 | ||
| Re: Tyre Pressures The tracking has been checked, it was toeing out as i thought, so its been adjusted now. Also the wheels have been swapped front to back, so ill keep an eye on the wear. ![]()
| | #27 | ||
| Re: Tyre Pressures
| | #28 | |||||
| Re: Tyre Pressures
| | #29 | ||
| Re: Tyre Pressures
| | #30 | |||
| Re: Tyre Pressures Looks like it held up well though! The stilo does have a very good safety record ![]() It shows how easy things happen though.
| Tyre Pressures | ricky952 | Barchetta | 4 | 06-01-2008 12:40 |
| Tyre Pressures | T-Jet 120 | Grande Punto | 2 | 16-12-2007 09:08 |
| tyre pressures | lottey | Doblo | 4 | 02-01-2007 22:16 |
| Tyre pressures | AIJ29 | Cinq/Sei > Technical | 9 | 13-12-2004 12:18 |
| Tyre Pressures | no1sourlung | Punto > Technical | 6 | 04-07-2004 18:16 |
