| Tyre Pressures what pressure should i be pumping my tryes up to to achieve the best performance?
| The modfather | There was a post somewhere about this stick 36/7 in the fronts and 35 in the rears..
| | #4 | ||
| It's about GO! not SHOW! | Re: Tyre Pressures Lots of threads on this (fairly) hot topic for the Stilo. A greater footprint (lower pressure) will give you better grip and also a softer ride. Higher pressure will always return better mpg. It will also tend to reduce uneven tyre wear and tyre wear in general but does generate a harsher ride. For performance considerations it's important to remember that tyre pressure is very tyre dependent and excessive pressure can degrade grip quite significantly (excessively under-inflated can be just as bad of course - although this tends to degrade the handling of the car rather than any actual reduction in grip) ![]()
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic Last edited by Argonought : 15-06-2008 at 14:41. | ||
| | #5 | ||
| Re: Tyre Pressures
| | #6 | ||
| Re: Tyre Pressures Last edited by Dogspods : 16-06-2008 at 08:37. | |||
| | #7 | ||
| The modfather |
| | #8 | ||
| Re: Tyre Pressures 2.3bar 17s all round as the book says,no probs with tyer wear.i do have aftermarket rims on tho much lighter
__________________ | |||
| | #9 | ||
| The Phoenix has landed! | Re: Tyre Pressures When I had the claws and Ultrac's fitted the garage filled them to 32psi and ive not noticed any performance/consumption issues!
__________________ Go Phoenix Go! Light Blue 3DR 1.6 Stilo Active - Francesca ![]() - Now with Giugiaro designed Vredestein Ultrac's! - Now with new Xenon's - 17" Stone Grey CLAWS | ||
| | #10 | ||
| Re: Tyre Pressures Mine: 215 45 R17 35 front / 33 rear. Seems ok... What do you experts think? ![]()
__________________ 1.6 16v / Skywindow / Clima / Cruise Control / CDA Air Intake Filter / Sparco Aluminum Pedals / Eibach Springs / Bilstein Yellow Shocks / HID Xenon 4300K XLS. / Cocconut Perfume![]() Ambition bites the nails of success | |||
| | #11 | ||
| It's about GO! not SHOW! | Re: Tyre Pressures I'd say yours are spot on and Coyotes is just a spot on the low side Having tyres at 37psi is very green but personally I'd feel a bid insecure generating a bit of 'g' on the curves ![]() Just depends how you drive really and how you value good mpg.
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | ||
| | #12 | ||
| Re: Tyre Pressures Handbook gives 2.1 bar (30.5 PSI) normal & 2.3 Bar (33.5 PSI) fully laden for 205/55VR16's. Have found that 32 PSI (2.2 bar) - 33 PSI is good in terms of comfort / fuel economy / tyre wear on the JTD... bearing in mind that the wheels are 16vt Coupe Alloys ![]()
__________________ Black 115 JTD, 16' 16vt Coupe alloys & debadged +147 Cruise Control NOW with added Millers Diesel Power Sport 4 | |||
| | #13 | ||
| It's about GO! not SHOW! | Re: Tyre Pressures Yes; I tend to use the fully laden figure of 33/34psi on my 205/55/16's most of the time Bit of a harsh ride on the P7's mind you. Have been thinking of lowering the psi a bit but price if diesel puts me off ![]()
| | #14 | ||
| Re: Tyre Pressures 36/7 sounds a little high. I have my standard steel wheels (195/65/15) at 33 front and 31 rear. The handbook says 29/30 all round but thats a little too low imo. I may try putting a little more air in, to see if it evens out my front tyre wear. To a degree, but once you get too low pressure, the sidewall will take most of the weight and the centre wont be taking much weight at all. So again there will be less of a footprint, as the centre of the tyre wont be pushed down onto the road as much.
__________________ 52 Fiat Stilo 1.6 Active - Fire engine red! | |||
| | #15 | |||
| 5 pots rule!! | Re: Tyre Pressures
no problems with handling
__________________ Previous Car : 2002 Mk2 Punto Active Sport in Broom Yellow Everday Car : 1999 Mk1 Punto Sporting in Silver Weekend Toy : Stilo Schumacher GP Last edited by red-devil : 18-07-2008 at 11:18. | |||
| Tyre Pressures | ricky952 | Barchetta | 4 | 06-01-2008 12:40 |
| Tyre Pressures | T-Jet 120 | Grande Punto | 2 | 16-12-2007 09:08 |
| tyre pressures | lottey | Doblo | 4 | 02-01-2007 22:16 |
| Tyre pressures | AIJ29 | Cinq/Sei > Technical | 9 | 13-12-2004 12:18 |
| Tyre Pressures | no1sourlung | Punto > Technical | 6 | 04-07-2004 18:16 |
