The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo > Stilo > Technical
Old 16-06-2008   #16
Dislikeskeyboardwarriors
Steely's Avatar
Trader Rating: (0)
Steely has donated! United Kingdom
Re: Rear torsion beam question??
Originally Posted by Argonought View Post
Ben, just reading up in leisure lounge and that was one hell of a mess you made of one of your wheels.
To finish it off, in your position, I'd take the car for a full 4 wheel alignment check (if you haven't already). If it checks out close to normal then you'll know for certain your chassis isn't distorted. Some places charge less than £15
yeah i know luckily the front shocker took most of the brunt of the knock, as you can see,, the rear wheel just brushed it, as soon as the new rims are on ive arranged for a heathcheck on the car at fiat, plus a 4 wheel setup on tracking,
one thing i remember when fitting the yakuza alloys first off was asking about the clearance between the rear arch inside walls and the distance between that and the tyre wall, which was 10mm, i did a check tonight and it is still the same 10mm, so it looks like its fine, but i will still get it checked for peace of mind, end of the day if it needs a new rear subframe, then a new rear subframe it is, pain in the arse thing is ive just seen a new one sell on ebay for 70 quid
cheers for the advice!
Steely is offline
Old 06-07-2008   #17
Steely's Avatar
Trader Rating: (0)
Right, and update.. ive done some research and found that:
The stilos rear subframe is adjustable up to 12 mm horizontal throw... purely just by the mounting points to the chassis,... undone 8 bolts and shifted the rear beam 7mm to the right... and running far straighter than ever...
will get some pics up soon..
Steely is offline
vB code is On
GT Rear Beam MattMk1 Punto > Technical 14 17-01-2008 21:49
punto gt rear beam/axle patrick Auction Watch 0 07-09-2007 06:39
For Sale: GT rear beam (FIAT Punto Parts) Puntosporting07 For Sale / Wanted 0 04-06-2007 00:27
torsion bar?? the beasto Cinquecento / Seicento 12 11-01-2006 16:15
Rear beam AIJ29 Cinq/Sei > Technical 4 10-08-2005 21:52
