The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo > Stilo > Technical
Old 14-06-2008   #1
Trader Rating: (0)
play on the wheel
hi can anyone help i have just had two bottom arms fitted on my 1.9jtd and there is still play on the wheel when its jacked up also when i brake it looks like the wheel is juddering
colin07 is offline
Old 14-06-2008   #2
NobodyBlamesTheHappyGuy:D
Morty Mort's Avatar
Trader Rating: (1)
Morty Mort has donated! Norway
Re: play on the wheel
Most likely the wheel bearing.
jet blue. 17" blades. eibach pro system. omp bar. gsr breath. mattig face. debadged. phoenix gold watts. rear tint.
member of the 5-door massive attack.
Morty Mort is offline
Old 14-06-2008   #3
Whaddya mean too old?
Deckchair5's Avatar
Trader Rating: (0)
Deckchair5 has donated! United Kingdom
Where is the play on the wheel?
If it's in horizontal plane and vertical plane then it could be wheel bearings/ wheel loose etc
If it's just in horizontal plane then it's more likely track rod end, steering rack worn etc
Look and see where the movement is when someone rocks the wheel or moves the steering
02 Stilo 1.6 Dynamic 3 door
99 Bravo 1.2SX
Deckchair5 is offline
Old 14-06-2008   #4
Trader Rating: (0)
cheers for the replys its like there is play in the bush in the bottom arm the whole hub the strut everthing moves side to side
colin07 is offline
Old 14-06-2008   #5
Deckchair5's Avatar
Trader Rating: (0)
If you've just had the bottom wishbone replaced then there shouldn't be any play down there any more.
Is the wheel/ whole hub moving around the horizontal?
Name:	track rod end.JPG
Is there play at the track rod end or steering rack end?
99 Bravo 1.2SX
Old 14-06-2008   #6
Trader Rating: (0)
its moving horizontal there is no play on the track rod ends or steering rack i cant work out what it could be are the any bushes or bearings at the top of the strut
colin07 is offline
Old 14-06-2008   #7
Deckchair5's Avatar
Trader Rating: (0)
I'm guessing it's the steeering rack inner knuckle joint. When you move the wheel to and fro in a horizontal plane look at the rod that's emerging from the steering gaiter. Is the rod moving a lot with the wheel hub movement or is it staying still?
If it's moving with the hub then it may be new steering rack time
99 Bravo 1.2SX
Old 14-06-2008   #8
Trader Rating: (0)
ok just checked the rack its solid no movment just lifted the bonnet and looked at the top of the struts on the nearside the ruber is flush on the offside there is about a half inch gap
colin07 is offline
Old 16-06-2008   #9
Trader Rating: (0)
Those wishbone bushes are quite springy. They do move a bit. I think it could be just normal.
WANTED: Faulty Connect Nav+ for parts, to fix mine.
john55 is offline
Old 17-06-2008   #10
Trader Rating: (0)
it knocks when i go over a bump also makes a strange noise when i turn left its got me beat cant work it out
colin07 is offline
vB code is On
Slight play up and down with steering wheel? robbocop Punto > Technical 1 06-02-2008 15:59
Up/Down Play in Steering Wheel 1998 Punto 'Team' woz Punto 8 11-12-2007 01:24
any one want a play around. luigipunto Imaging 5 17-06-2007 15:23
Having a play Alan.D Panda (Classic) 22 10-11-2005 23:18
Steering wheel play... klr142 X1/9 6 18-12-2004 16:11
