| play on the wheel hi can anyone help i have just had two bottom arms fitted on my 1.9jtd and there is still play on the wheel when its jacked up also when i brake it looks like the wheel is juddering
| NobodyBlamesTheHappyGuy:D | Re: play on the wheel Most likely the wheel bearing.
__________________ jet blue. 17" blades. eibach pro system. omp strut brace. gsr breath. mattig face. debadged. phoenix gold watts. member of the 5-door massive attack. | ||
| | #3 | ||
| Whaddya mean too old? | Re: play on the wheel Where is the play on the wheel? If it's in horizontal plane and vertical plane then it could be wheel bearings/ wheel loose etc If it's just in horizontal plane then it's more likely track rod end, steering rack worn etc Look and see where the movement is when someone rocks the wheel or moves the steering
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX | ||
| | #4 | ||
| Re: play on the wheel cheers for the replys its like there is play in the bush in the bottom arm the whole hub the strut everthing moves side to side
| | #5 | ||
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX Last edited by Deckchair5 : 14-06-2008 at 19:43. | ||
| | #6 | ||
| Re: play on the wheel its moving horizontal there is no play on the track rod ends or steering rack i cant work out what it could be are the any bushes or bearings at the top of the strut
| | #7 | ||
| Whaddya mean too old? | Re: play on the wheel I'm guessing it's the steeering rack inner knuckle joint. When you move the wheel to and fro in a horizontal plane look at the rod that's emerging from the steering gaiter. Is the rod moving a lot with the wheel hub movement or is it staying still? If it's moving with the hub then it may be new steering rack time
| | #8 | ||
| Re: play on the wheel ok just checked the rack its solid no movment just lifted the bonnet and looked at the top of the struts on the nearside the ruber is flush on the offside there is about a half inch gap
| | #9 | ||
| Re: play on the wheel Those wishbone bushes are quite springy. They do move a bit. I think it could be just normal.
__________________ WANTED: Faulty Connect Nav+ for parts, to fix mine. | |||
| | #10 | ||
| Re: play on the wheel it knocks when i go over a bump also makes a strange noise when i turn left its got me beat cant work it out
| Slight play up and down with steering wheel? | robbocop | Punto > Technical | 1 | 06-02-2008 15:59 |
| Up/Down Play in Steering Wheel 1998 Punto 'Team' | woz | Punto | 8 | 11-12-2007 01:24 |
| any one want a play around. | luigipunto | Imaging | 5 | 17-06-2007 15:23 |
| Having a play | Alan.D | Panda (Classic) | 22 | 10-11-2005 23:18 |
| Steering wheel play... | klr142 | X1/9 | 6 | 18-12-2004 16:11 |
