| Radio reception fault Does anyone know why I have lost reception from any radio channel?. AM, FM and LW are all as bad. All I get is the sort of hissing and buzzing sound that comes when a radio aerial gets disconnected or when you are not tuned into a station. The CD player works fine and the radio tuner will switch as normal between the pre-set channels but I am wondering if I have somehow accidentally disconnected the aerial and if someone might know where to look! Thanks!
| Re: Radio reception fault Firstly, remove the unit from the dash and check if the areal plug has fallen out of the back.
__________________ WANTED: Faulty Connect Nav+ for parts, to fix mine. | |||
| Radio reception | digger58 | Ulysse | 4 | 09-11-2007 10:08 |
| Radio Reception | Ross Coventry | Stilo > Technical | 10 | 02-05-2007 15:31 |
| Improving radio MW reception | largeinnit | I.C.E | 1 | 22-05-2006 00:40 |
| radio reception | stalemate | I.C.E | 5 | 15-04-2005 22:48 |
| Bad Radio Reception | david palmer | Stilo > Technical | 3 | 04-06-2004 21:31 |
