The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo > Stilo > Technical
Old 12-06-2008   #1
Trader Rating: (0)
Clutch Gone
For about the past two weeks my clutch has been very jerky when pulling off. But today i was driving back from work came up to a corner and changed into second and nothing. No bite just revs in whatever gear you put it in.
Could it be the Clutch Slave Cylinder or do you think the clutch has completely gone before i go and get it sorted.
Stilo 1.6
72k
2002
thanks
Stu
stu_2k1 is offline
Old 12-06-2008   #2
The Red Devil
adamcot's Avatar
Trader Rating: (0)
adamcot has donated! United Kingdom
Re: Clutch Gone
When my slave cylinder failed, the pedal went straight to the floor... If youve got any pedal travel, then it must be something more serious
Fiat Stilo 1.6 16v Dynamic 3 door in Scilia Red, Abarth body kit and Connect Nav +.
adamcot is offline
Old 12-06-2008   #3
Wants a Murcielago LP640
fiattech's Avatar
Trader Rating: (0)
fiattech has donated! United Kingdom
Re: Clutch Gone
It may be that the friction material has come away from the friction plate - so when you press the clutch it squeezes the unit together allowing gears to be selected, but the torque is not transferred from the engine to the input shaft of the gearbox.
You need to have the gearbox removed and the clutch inspected / replaced most probably, 72k is around the mileage of failure TBH.
Fabrica Italiana Automobili Torino
P2 Stilo Abarth GT - Imola yellow.
"power is nothing without control"
Originally Posted by jug View Post
few things compare to giving your mate a high 5 as you spitroast a drunk girl.
fiattech is offline
Old 13-06-2008   #4
PNL
The modfather
PNL's Avatar
Trader Rating: (0)
PNL has donated! United Kingdom
Cool Re: Clutch Gone
looks like the clutch has had it..
PNL is offline
Old 13-06-2008   #5
Trader Rating: (0)
Re: Clutch Gone
Thanks for all the replys.
Theres no pedal play. The same as before. Im going to get it replaced. Maybe have to sell a kidney.
stu_2k1 is offline
vB code is On
Clutch master cylinder (Clutch not seperating properly) 57mmStroke Multipla 4 15-06-2008 20:22
Clutch release baring problem? Squeeky clutch! RobsonGTO Punto > Technical 1 26-09-2007 21:17
Gringing And Scraping Noise When Clutch Released Only Stops When You Depress Clutch allsortspete Punto > Technical 4 05-07-2007 20:45
Changing hydraulic clutch gearbox to take a cable clutch? 4paws Uno > Technical 10 23-03-2006 14:56
wil changing my clutch cable make it eaiser to push my clutch down luke64 Cinq/Sei > Technical 6 19-12-2005 13:36
