| Lowering Springs?? Hey guys! I would like to lower my stilo (1.4 3 door) Any recommendation on brand? Or how much i should lower it!? Im thinking sort of Rear 50mm ish front 40mm ish!?? Also... Im really having trouble getting hold of any springs at all for a 1.4!! or am i being stupid and the 1.2 or 1.6 ones will fit!? So any links and pictures would be great! Thanks! Fletch!
| | #2 | |||||
| Re: Lowering Springs??
![]() http://www.potn.co.uk/p1331655.htm
| | #3 | ||
| Re: Lowering Springs?? Thanks dude Any others...Or is that my only choice?
| | #4 | ||
| It's about GO! not SHOW! | Re: Lowering Springs?? Your only choice really is Eibach (masses of threads if you use search). Unless you intend to change dampers as well then don't drop lower than 30mm (unless you like crap handling
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | ||
| | #5 | ||
| The modfather | Stick with the standard set up you will be far better off..
| | #6 | ||
| NobodyBlamesTheHappyGuy:D | Re: Lowering Springs?? Either you go standard or do the complete Eibach pro set with 30 mm drop including dampers. Morten.
__________________ jet blue. 17" blades. eibach pro system. omp bar. gsr breath. mattig face. debadged. phoenix gold watts. rear tint. member of the 5-door massive attack. | ||
| | #7 | ||
| | #8 | |||
I lowered the Uno I had for the first time about 5 years ago, with another brand of springs if I recall correctly. Handling was great for half a year. Then the dampers were shot like bicycle pumps. So, I would never lower a car without changing to sport shocks at the same time. I guess it is possible to mix and match to find great solutions, but the Eibach set seems pretty well balanced regarding enthusiastic handling and family comfort. My Stilo got the complete Eibach set in march 07 and has been perfect since. Morten.
__________________ jet blue. 17" blades. eibach pro system. omp bar. gsr breath. mattig face. debadged. phoenix gold watts. rear tint. member of the 5-door massive attack. | |||
| | #10 | ||
| Re: Lowering Springs?? I'll be getting the Eibach springs and dampers at the same time. Can get the whole deal for well under £400 from here, though the springs themselves are separate from the dampers... http://www.potn.co.uk/ Springs... http://www.potn.co.uk/p1331655.htm Dampers... http://www.potn.co.uk/p1338152.htm Fitting will probably bring the total cost up to around £500, which I think is pretty reasonable.
__________________ 2003 3dr 1.2 16v Stilo Active in Grigio Steel - De-badged rear and wings, Kamei look mesh de-badged grille, Red Painted Callipers, Fiat Alloy Pedals, Richbrook Aerial/spinner dust caps/tax disc holder/Poppy Coral Air Freshener in Silver, Ripspeed mats and lighter. | |||
| Lowering springs | gareth.j.h | Punto > Technical | 34 | 24-04-2008 12:01 |
| Lowering Springs | matty_316 | Grande Punto > Styling | 2 | 23-01-2007 19:34 |
| p.i lowering springs | GHOST | Punto > Technical | 0 | 13-07-2005 17:45 |
| Lowering Springs | Cinq_Sport_BiG_DaVE | Cinq/Sei > Styling | 5 | 19-01-2005 19:26 |
| lowering springs (again!) | punto urban racer | Punto | 7 | 12-01-2005 19:00 |
