| CAT Problems... Solution Needed pos Performance ???? I have a 1.6 16v dynamic 3 door 52 plate stilo I have been told my cat had blown. There is a massive ratttle everytime i drive the car coming from the centre box. 12 months ago i had the centre box and back box replaced so its not that. the engineer at Hi Q said the cat has blown and the ceramic parts of the cat have been forced in the centre box hence the rattling. I have been told i need a new cat and centre box ( couldnt obtain a quote from Hi Q Fiat Quoted me £800 I am told there are two cats and it is also part of the manifold from what i can see. I rang the local performance centre and they cant do it ( MIJ Performance) they only do cat back for my car!!! Anyone got any idea's??? if there not much difference in price i may aswell buy Performance ! | |||
| | #4 | |||
| Wants a Murcielago LP640 | Re: CAT Problems... Solution Needed pos Performance ????
| | #5 | |||||
| The modfather | Re: CAT Problems... Solution Needed pos Performance ????
| | #6 | ||
| Re: CAT Problems... Solution Needed pos Performance ???? dear : You can buy the Cat converter from him www.catman.co.uk cost around £ 280 for the whole unit but you have to get someone ( garage to fits it for you ) labour around £ 60 pounds 2 hours job . however ,make sure you bring to few garage to check ,i had the problem before ,and they said my CAT is gone ,however i called to FIat dealership ,they told me ,they have never received and seem any fiat stilo car where the CAT was broken down . If i were you ,i will get it recheck from a reputable garage .
| | #8 | ||
| The Red Devil | Re: CAT Problems... Solution Needed pos Performance ???? A mate of mine is a mechanic, he checked mine when it "failed" lol under the bonnet, to the rear of the engine cover - there is the exhaust manifold. If you tap the manifold with a stick or somthing, you should hear no rattles. If it rattles, then the cat has broken down inside. You should also be able to smell an eggy smell, and possibly a loss in performance and even maybe an engine management light.
__________________ ![]() Fiat Stilo 1.6 16v Dynamic 3 door in Scilia Red, Abarth body kit and Connect Nav +. ![]() | ||
| | #9 | ||
| Re: CAT Problems... Solution Needed pos Performance ???? i have smelt a strong eggy smell every now and again! the fact the centre box and back box was replaced about 8 months ago brings me to the conclusion its the CAT !!! How much labour am i looking for a garage to fit a new cat and centre box i have a quote for £325.85 from catman (centre box and cat/manifold) | |||
| Cat Problems | JOHNSHAFT | Stilo | 9 | 08-07-2007 10:28 |
| Solution much needed, loud banging noise... | SilentPartner | Bravo/a > Technical | 5 | 16-04-2007 09:04 |
| De-Cat pipe/ Cat problems | softwarez | Punto > Technical | 8 | 23-11-2005 23:38 |
| Cat problems? | softwarez | Punto > Technical | 2 | 17-11-2005 16:21 |
| Possible solution for electrical problems | Djomla | Stilo > Technical | 3 | 19-04-2005 14:49 |
