The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 07-06-2008   #1
minimad99's Avatar
Trader Rating: (0)
minimad99 has donated! United Kingdom
how to change lower suspension arm
I've done this as a seperate thread for ease of searching in the future.
Is changing a lower suspension arm a DIY job or is any special kit required?
Could someone write a brief step by step for me.
thanks
3 Door Sprint Blue JTD with Skyroof, 17 inch Fox R1 alloys,-30mm Eibach Springs, Boge Turbo shocks, OMP Strutbrace, Mattig Badgeless Grill, RED.DOT Grooved brake discs and pads
RED.DOT RACING TUNED - to153BHP/201FTLB TORQUE
minimad99 is offline
Old 07-06-2008   #2
a1ant's Avatar
Trader Rating: (0)
a1ant has donated! United Kingdom
Re: how to change lower suspension arm
Hello mate,
You can do it yourself, fairly easy job....... (now i'm doing this from memory as i sold my stilo a few months ago so cant go check exact sizes, but have done a fair few)
1, Jack the car up, (support on axel stands)
2, Remove Wheel
3, Undo the 13mm bolt that secures the ball joint to the hub
4, Use ball joint separator or appropriate tool to remove ball joint.
5, Undo the bolts holding the anti-roll bar to the lower arm
6, Undo the 13mm bolts that secure the front mount of the control arm
7, Undo the 19mm bolt that secures the rear of the control arm
8, Remove control arm
The do the reverse to put it all back...lol
Hope that helps,
Alan
Seicento Sporting 1.1, Punto 1.9 JTD, Punto 1.3 Multijet, Bravo T-Jet 150 Sport, Impreza STi PPP
Links to guides - JTD Crank Sensor
, Punto Juddering Wipers , JTD MAF sensor Bravo 198 Warning lights Bravo 198 Service Schedule
a1ant is offline
The following user says "Thank You!" to a1ant for this useful post:
minimad99 (08-06-2008)
Old 07-06-2008   #3
Whaddya mean too old?
Deckchair5's Avatar
Trader Rating: (0)
Deckchair5 has donated! United Kingdom
And here's somes piccies to help you on your way. This is a French Stilo so things may look a little backward - spot the exciting and definitely not recommended method of using jacks here
02 Stilo 1.6 Dynamic 3 door
99 Bravo 1.2SX
Deckchair5 is offline
The following user says "Thank You!" to Deckchair5 for this useful post:
Old 08-06-2008   #4
minimad99's Avatar
Trader Rating: (0)
cheers Decks,
You're a legend.
Old 09-06-2008   #5
NobodyBlamesTheHappyGuy:D
Morty Mort's Avatar
Trader Rating: (1)
Morty Mort has donated! Norway
Originally Posted by minimad99 View Post
cheers Decks,
You're a legend.
And still alive.
jet blue. 17" blades. eibach pro system. omp bar. gsr breath. mattig face. debadged. phoenix gold watts. rear tint.
member of the 5-door massive attack.
Morty Mort is offline
Old 09-06-2008   #6
Deckchair5's Avatar
Trader Rating: (0)
Hi Morty! I'm still kicking
Drove a motorbike for the first time in 30 years tonight. A Bonny! (Triumph Bonneville) Bike was nearly as old as me. Still buzzing
Forgot how bad the brakes were
99 Bravo 1.2SX
Old 09-06-2008   #7
Morty Mort's Avatar
Trader Rating: (1)
Hehe. I took the motorbike theoretical exam when I was serving time in the Norwegian army. Then after testing the bikes, I put it on the shelf. Something told me this was going to kill me. So I never took the license...
Tags
change, lower suspension arm
(T) Changing the Front lower suspension arm ChrisMClark Stilo 17 05-09-2007 23:08
(T) Lower Front Suspension Arm G Spag Stilo 6 14-04-2007 04:12
(T) O/S Lower Suspension Arm leelee01 Stilo 6 04-02-2007 03:31
(T) Lower suspension arm (Wishbone) DAlex Marea 8 03-12-2006 00:56
(T) Changing front suspension arm bushes(change to guide format) peaster2k Cinquecento / Seicento 2 21-02-2005 19:57
