| how to change a track rod end Hi all, I've had some knocking and slight vague steering for a while but have just put up with it. Well i've got some holiday coming so thought i'd enjoy myself and do some work on the stilo. I've already got the droplinks ready to be changed but thought i'd also change the track rod ends at the same time if they are a DIY job. I believe they are all the original parts, if not then they have definately covered 70,000 miles since i've had it so should be ready be changing, LOL Can anyone write a step by step guide for me and include any specific tools required, i know i need to buy a balljoint splitter but anything else? Should i use OE spec ones, such as http://www.shop4parts.co.uk/index.cf...catalogue.list at £22 plus VAT or have a chat with my local motor factor Ta
__________________ ![]() 3 Door Sprint Blue JTD with Skyroof, 17 inch Fox R1 alloys,-30mm Eibach Springs, Boge Turbo shocks, OMP Strutbrace, Mattig Badgeless Grill, RED.DOT Grooved brake discs and pads RED.DOT RACING TUNED - to153BHP/201FTLB TORQUE Last edited by minimad99; 07-06-2008 at 17:37. | |||
| ^^^^^^ | Re: how to change a track rod end Hello mate, .....again from memory as no stilo on the drive to check measurement but.... 1, Jack car up 2, Remove wheel 3, Measure the distance between the end of the threads and the end of the old track rod end (also check that the new track rod ends are the same length as the old ones, if not...make allowance for this) 4, Loosen the nut at the end of the track rod end (steering rack side) (not to much as you can use it as a reference point to do the new track rod end up to... 5, Undo the nut attaching track rod end to the steering knuckle 6, Use ball joint separator to remove ball joint from knuckle. 7, Unscrew track rod end from steering rack.... throw in bin etc 8, Screw new track rod end on to steering rack shaft. Stop by the nut you left and when the measurements are correct, 9, Tighten nut at steering rack side of track rod end. 10, Put ball joint back in steering knuckle 11, Do up bolt securing track rod end to steering knuckle. 12 (I would advise) Get tracking checked. Hope that helps, Alan
__________________ ![]() Seicento Sporting 1.1, Punto 1.9 JTD, Punto 1.3 Multijet, Bravo T-Jet 150 Sport, Impreza STi PPP Links to guides - JTD Crank Sensor, Punto Juddering Wipers , JTD MAF sensor Bravo 198 Warning lights Bravo 198 Service Schedule | ||
| The following user says "Thank You!" to a1ant for this useful post: | ||
minimad99 (08-06-2008) | ||
| | #3 | ||
| Whaddya mean too old? | Re: how to change a track rod end No real need to stick with Fiat's own brand if you can find alternatives As your tracking may well be altered then you're either looking at a steering alignment being required after the job or, if you check out your steering the way I describe in the Stilo Guides, then you can put your steering accurately right back to where it was at the end but you need to check it out BEFORE you start the job It's a very quick job to do but loosen the rod end lock nut just a fraction first before you do anything else as it's usually very tight. Leave the locking nut there as it will help guide you to put the new track rod end in close to the right place on refitting. There's some flat sides on the track rod end for the right sized spanner to provide a counter force If the ball joint breaker won't make the joint break, give the ball joint splitter a sharp blow with a hammer directly on the joint As you'll need to rotate the track rod arm to align the tracking, loosen the steering rack gaiter's grip on the track rod end as it usually sticks to the rod with time and will fold up and tear if it's not free to rotate Always a smart idea to use axle stand anyway but you could do with your hyd jack free in case you need to jam the new track rod end taper in tight so you can tighten the securing nut For the antiroll bars joints you can easily hold their ball joints on the weatherproof gaiter with a mole wrench to stop them from spinning as the gaiter is very tough and that makes the whole job possible in minutes
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX Last edited by Deckchair5; 07-06-2008 at 18:34. | ||
| The following user says "Thank You!" to Deckchair5 for this useful post: | ||
| | #4 | ||
| Re: how to change a track rod end cheers guys
__________________ ![]() 3 Door Sprint Blue JTD with Skyroof, 17 inch Fox R1 alloys,-30mm Eibach Springs, Boge Turbo shocks, OMP Strutbrace, Mattig Badgeless Grill, RED.DOT Grooved brake discs and pads RED.DOT RACING TUNED - to153BHP/201FTLB TORQUE | |||
| | #5 | ||
| Well i completed this today on both sides, along with replacing both wishbones and both droplinks. Was relatively straight forward apart from a couple of stubborn bolts. QUESTION; The only thing that i can't find an answer for is, how do you fully tighten the track rod end nut? It came with a nylock nut so won't come undone but i can't find the torque setting on elearn, also when you tighten it so far it would start to spin surely? I have fully tightening it with a standard ratchet but when using a torque wrench set around 70Nm it still turns, hence this post. Could one of you confirm for me if this is the correct? ta
| | #6 | |||
| Dislikeskeyboardwarriors | Re: how to change a track rod end
the track rod end nuts are there purely for tracking, the nylock is to stop the nuts as they dont fully tigthen up, adjusting the nuts will cause the wheels to pos or neg Tow have a looky here http://www.etyres.co.uk/glossary-tyr...nment-tracking
__________________ | |||
| | #7 | ||
| Whaddya mean too old? | Re: how to change a track rod end Are you both talking about the same thing? Track rod end has a locking nut item 1 next to it, you turn the track rod (also called tie rod) to adjust the tracking and the lock nut locks it up. This isn't a nylock nut though The nylock nut holds the tapered track rod end ball joint in the hub track arm and i think this i what minimad refers to. If this is spinning then put a hyd jack underneath to force the taper joint to hold whilst you tighten the nut
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX | ||
| | #9 | |||
__________________ ![]() 3 Door Sprint Blue JTD with Skyroof, 17 inch Fox R1 alloys,-30mm Eibach Springs, Boge Turbo shocks, OMP Strutbrace, Mattig Badgeless Grill, RED.DOT Grooved brake discs and pads RED.DOT RACING TUNED - to153BHP/201FTLB TORQUE | ||||
| | #10 | ||
| Whaddya mean too old? | Re: how to change a track rod end 3 white knuckles tightness Yep as long as it's holding the taper joint in tight then no need to over do it
| Tags |
| change, changing, end, rod, track |
| | lei mancell | Bravo / Brava | 2 | 16-07-2007 00:54 |
| | marts600 | Marea | 6 | 15-02-2007 11:05 |
| | socheeky | Cinquecento / Seicento | 7 | 10-09-2006 18:29 |
| | jamie86 | Cinquecento / Seicento | 4 | 14-12-2004 11:18 |
| | arseofbox | Cinquecento / Seicento | 18 | 22-07-2004 22:20 |
