The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 01-06-2008   #1
Trader Rating: (0)
OBD 1.6 Connector - Where is it ?
I have a 1.6 Dynamic, 2002 vintage. I've recently bought an OBD reader, and I can't locate where to plug it into the car !
Its the usual D type, 8x8 pins. I've looked around inside the fuse box cupboard, but I can't find a loose cable or connector on a circuit board to plug it into. On the right side of the fuses, there is a large black plastic connection, with wires coming out of the top - this looks like it should be unplugged, to plug the connector in. But ... something tells me I'm doing something wrong. It must be a stand alone connection point, I can plug into.
Where can I find it ?
On a different note, I have an OBD-DIAG diagnostic reader, which handles both the ISO and KWP 2000 protocol. I'm sure the Stilo uses ISO (I hope so !).
Regards.
jjmoore27 is offline
Old 01-06-2008   #2
Trader Rating: (0)
Netherlands
Re: OBD 1.6 Connector - Where is it ?
it is under the fuses behind the panel on the right side of your steering wheel (in UK, mine is left in the Netherlands...)
it is a black, fixed 16 pins female connector on the grey body-computer which is connected to the back of the fuse box ....
yellowstilo is offline
Old 01-06-2008   #3
It's about GO! not SHOW!
Argonought's Avatar
Trader Rating: (0)
Argonought has donated! United Kingdom
Lightbulb Re: OBD 1.6 Connector - Where is it ?
Look towards the top (above all the fuses) and towards the rear.
A torch makes it a lot easier to find and make sure you plug it in the correct way up (can be quite a push the first time - a slight smear of WD40 helps a lot)
Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic
Argonought is offline
Old 01-06-2008   #4
Trader Rating: (0)
Thanks for all the help. I'll take another look tomorrow. It sounds like its fixed into the plastic housing, and not hanging around on the end of a cable. Which probably explains why I didn't find it - I was looking for the wrong thing.
(T) Seicento Mk1 OBD Connector LanciaMad Cinquecento / Seicento 2 23-05-2008 13:06
(T) Where is the OBD II connector in my Marea Weekend? TBMonsen Marea 5 11-07-2007 13:45
Where is the OBD-II connector?? sjladopoulos Barchetta 4 03-06-2007 09:57
Making an OBD to Fiat connector mountainmachine Lets Talk FIAT 3 26-03-2007 14:26
(T) OBD Socket Tim T Stilo 5 19-07-2006 19:00
