The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 01-06-2008   #1
Shminkypinky's Avatar
Trader Rating: (0)
Oil Additives to improve consumption.
I have an 02 reg 3dr 1.6 Stilo Dynamic with 61000 miles on the clock.
I do approximately 800-1000 miles per month and currently use 1-1.5 litres of oil in that time.
FIAT suggest this is normal but it seems high to me and I seem to be always topping up.
There are 100% no oil leaks from the engine and no blus smoke from the exhaust.
I do not use expensive Castrol GTX magnatec or Selenea due to its expensive price and if im topping up all the while it would be expensive. I use 10W 40 Quantum oil. The mechanic who I use for servicing etc suggested I use this oil as it would create carbon build up around the piston rings to try and stop the oil passing the piston. Apparently VW and Skoda are experiencing similar problems so are using non synthetic oils for the same reason - this is why he has suggested this (around 9 months ago now)
I have never had the 'low oil pressure' warning come up on my display but quite often there appears to be NO oil on the dipstick guide (the flat part) so I assume it needs a top up so I feed it. I top it up so I get it about 3/4 of the way on the flat of the dipstick as I'm worried about overfilling it.
Question 1: Am I reading the dipstick correctly, is the flat part of the dipstick the guage and if it is off the bottom of the guage how much oil is remaining in the sump?
Question 2: I have been looking at oil additives to try and improve oil consumption and have been looking on the Wynn's website - www.wynns.uk.com
When I click on 'problem solving' for retail, wynns suggest this product:
http://www.wynns.be/product.aspx?nav...0&p=47044&l=EN
Super Friction Proofing®
Super Friction Proofing® improves lubrication, keeps the lubricating system clean and reduces friction.
Ref. Nr. 47044 - 325 ml
Properties
Reduces friction and wear.
Conditions metal surfaces and puts a protective layer on them.
Reduces oxidation and premature thickening of the oil.
Prevents formation of deposits and sludge.
Retards fouling of the oil filters.
Applications
For all petrol and diesel engines with or without turbochargers.
Recommended for old as well as new vehicles after the running-in period.
Directions
325 ml treats 3 to 6 litres engine oil (every oil change)
However when I click the same problem for Trade it suggests this product:
http://www.wynns.be/product.aspx?nav...9&p=74944&l=EN
Super Charge®
improves the high temperature viscosity properties of engine oil and stops oil leaks.
Ref. Nr. 74944 - 325 ml
Properties
TÜV approved.
Reduces excessive oil consumption via piston rings and valve guides.
Increases the viscosity index of the oil.
Rejuvenates rubber oil seal rings and O-rings.
Restores compression and oil pressure.
Applications
Effective under heavy load and high temperature operation.
Specially recommended for older engines.
Directions
325 ml treats 3 to 6 litres engine oil (every oil change).
Thet are suggesting 2 different products for the same problem to retail and trade - seems strange
So my question is what is the difference? and which one should I purchase (if any)? and has anyone had any experience with these products and have they been effective.
Many Thanks any advice would be greatly received.
Fiat Stilo 3dr 1.6 Dynamic - pretty standard.
Shminkypinky is offline
Old 01-06-2008   #2
PNL
The modfather
PNL's Avatar
Trader Rating: (0)
PNL has donated! United Kingdom
Cool Re: Oil Additives to improve consumption.
I used to use it when I was grass track racing years ago ..but you shouldnt need it for a road going car ..you might have a cracked ring and thats why you have blow by ..quick check would be to whip out the spark plugs to see if they are contaminated..
International man of mystery
Wit ..sarcasm you get it all from me..
PNL is offline
Old 01-06-2008   #3
Trader Rating: (0)
a complete waste of money.....these additives do not work at all, they are a money making item..simple as that. there is a link to back up what i,ve said aswell, but i,m not too good doing the link thing....ask yourself this question even if they do work[they dont] what about your oil filterif its doing its job proparly all the so called good stuff will be filtered out
jimboy is offline
Old 01-06-2008   #4
It's about GO! not SHOW!
Argonought's Avatar
Trader Rating: (0)
Argonought has donated! United Kingdom
I'd say you're reading the dipstick properly and you certainly don't want to let it drop below the minimum mark (or not showing at all )
I also concur with the last two posts. An oil addictive can often be a short step to another engine (and I speak from direct experience )
Check the plugs and see just how bad the problem is (or isn't)
Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic
Argonought is offline
Old 01-06-2008   #5
Trader Rating: (0)
What experience have you had with another engine Argonought?
Surely these additives must do something or how can they continue to sell and advertise them? are they really useless?
Old 01-06-2008   #6
Andy Monty's Avatar
Trader Rating: (0)
Andy Monty has donated! United Kingdom
have a read of this loads more about
http://www.fordscorpio.co.uk/snakeoil.htm
Originally Posted by Most Easterly Pandas View Post
Massive gash
Andy Monty is offline
Old 01-06-2008   #7
Argonought's Avatar
Trader Rating: (0)
To be fair it wasn't Wynn's but STP oil treatment (but still a direct competitor).
My car at the time, a Honda sports car, was using a bit of oil (rather like yours) so decided to give STP a go after careful consideration (just like you).
Put in a can at Reading but didn't even make it back to Dorchester (about a 100 miles). Stacks of smoke, low power and the engine felt like it was about to seize. Managed to get to the first garage I could find, dumped the sump and filled with fresh oil. This at least got me home but the damage was now done and I had to rebuild the engine
Old 01-06-2008   #8
Trader Rating: (0)
WOW - that article is an eye opener and from your replies you have certainly talked me out of using anything! Argo - your experience certainly makes you wonder! - Did you have any proof it was the STP that ruined your engine and did you contact them for an explanation?
I think the fact that no oil companies or car companies endorse these additives speaks volumes as the article says, if they worked why wouldn't they recommend them??????
So I will not be using any additive to try and solve the problem.
Does anyone have any recommendations on what I sould try next? or shall I just continue to top up when required. I have worked out that since my last service on 26th April 08 I have used around 2 litres of oil - I have just been to Scotland (around a 1000 mile round trip) that + my usual 1000 mile a month commute to work etc adds up to around a litre every 1000 miles which is what FIAT state as normal so am I just being paranoid?
I would like to stress that the car drives absolutley superb and there are no problems to report from it running (touches wood!)
The problem is that I am concerned as I love the car and do not want to have to replace it so just want to make sure it survives another 61000 if possible!
Thanks for all your replys so far - its much appreciated.
Old 02-06-2008   #9
Trader Rating: (0)
well done andy monty thats the link i was talking about.
& yes it is an eye opener
jimboy is offline
Old 02-06-2008   #10
Shropshire UK
Ffoxy's Avatar
Trader Rating: (0)
Ffoxy has donated! United Kingdom
Additives :- Time x Money = Waste of.
Ex Suzuki SV1000S jockey, now just me and my 1.9 MJet Grande Punto Sporting in New Orleans Blue. 193.8 Bhp and 261ft lbs torque.
Ffoxy is online now
Old 02-06-2008   #11
Stilatos's Avatar
Trader Rating: (0)
Greece
1.6 silver dynamic 3d with skywindow, Schumacher Look, Abarth Pedals,Brembo Brakes,Bilstein Eibach Suspension, Eagle F1 Tires, K&N Filter,Sport Steering Wheel,Sport Knob,3M tint.Philips New Vision Lights. Founder & Admin of the Greek Stilo club www.stiloclub.gr
Stilatos is offline
Old 02-06-2008   #12
PNL
The modfather
PNL's Avatar
Trader Rating: (0)
Mmmm you been scanning our site I see..
PNL is offline
Old 03-06-2008   #13
Stilatos's Avatar
Trader Rating: (0)
Greece
actually i have been watching this guys page for years i think its a great resource for someone to learn the automotive basics. i made my gf read it and finally stops whining for simple things like how to check the oil and coolant level.
Stilatos is offline
Old 03-06-2008   #14
EgyTuner.com...
OzMoSiS's Avatar
Trader Rating: (2)
OzMoSiS has donated! Egypt
i use millers diesel sport in my JTD, and after i while i thought i wasnt worth the money so i stopped using it.
a few weeks ago i thought id give it another try, and it CERTAINLY does a lot of difference, not much economy wise, but a lot in terms of smoothness, responsiveness and decreasing smoke.
as long as i can afford it, i'll be using it
Originally Posted by dan-the-man View Post
i only have one nipple
Check out my items in the classifieds section HERE
OzMoSiS is offline
(T) do you use oil additives ktmmark Punto 9 08-04-2008 21:24
Oil additives in engine or gearbox? combwork Multipla 0 04-10-2007 02:50
Oil additives fiat_freak Leisure Lounge 2 30-03-2007 21:43
