| Timing belt on stilo Hi lads,My 03 1.2 stilo has just done 48k miles and i have been on to my local fiat garage in cork,ireland and am getting mixed answers. One garage says its overdue,should be done@ 36k other garage says wait till 65k as the car was always serviced there and never misused as the garage foreman knew previous owner. What do ye think? Also they both say not to change the water pump €81 as at 48k its good till next belt!! I do 5k max miles per year and dont mistreat it. Also if doing exactly what parts should be changed? Fiat mention the timing belt kit for €75,does this have all i need? Also how many hours would fiat take to change it? Any advice welcomed. Regards, kieran
| | #3 | ||
| one with the dark side | Re: Timing belt on stilo it should be checked at 36000 miles for wear and if needed changing. 72k or 5 years is what Fiat reckon is the maximum interval, but in the real world its best to stay to 40000 miles or 4yrs to be safe. If the water pump is driven by the cam belt then its always best to change it as a new water pump will mean the belt replaced anyway so its more cost effective in the long run, as well as any idler pulleys etc also. | ||
| | #4 | ||
| Re: Timing belt on stilo Hi,So ye reckon i should get this done?Okay,i will get it booked in. Fiat were charging me id say for 3 hours work,so this should be a lot less? If i was going to a local mechanic who is very good,what parts should i order for him? timing belt kit. auxilkiary belt water pump idler Or is this wrong? Also should i get if possible a non fiat water pump?Would it keep costs down? Thanks for the replies guys. Regards, Kieran
| | #5 | ||
| It's about GO! not SHOW! | Re: Timing belt on stilo Might be different in Ireland but in the UK, under FiatCare main dealers have been fitting full belts kits for £150 inc (parts & labour). Use Search and you'll find stacks of info on this. Personally, I'd change the belt after 5 years which is most likely up anyway.
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | ||
| | #6 | ||
| | #7 | ||
| It's about GO! not SHOW! | Re: Timing belt on stilo You need to buy the full kit (not just the belt) although I'm certainly no expert on the 1.2 There tend to be a fair number of posts on here of people not getting the job done properly when the belt is changed (often becoming terminal for the engine ) so make sure you're happy with whoever is going to do the job.
| | #8 | ||
| Whaddya mean too old? | Re: Timing belt on stilo i think the 1.2 is the easiest of the bunch to do a cambelt change. Cambelt kit will have belt and tensioner so you just need water pump if you're doing it and aux belt. If you have a separate air con belt then you'd need one of those too (I think yours is all one belt) No idler on the 1.2, just straight over the cam, around the water pump, around the crank pulley sprocket up around the tensioner and that's it. Wise to change the water pump as they tend to start leaking at 60k miles. Haven't ever had a problem with non Fiat water pump Maybe an hour for the job and a very important 30 minutes for rotation clearance checks, stretching the belt and finally setting up the tension and double checking the timing is still correct. A lot of garages don't do that and that's where the problems happen. No way should a car come out the garage with the timing not set up right, just have to simply double check when everything's finally fitted but too many can't be bothered. Must be 6 Stilo owners on here alone that have found their timing not set up correctly after a cambelt change. TIP your car should never run worse after a cambelt change, it might run better but never worse. Check it out when you pick it up. Bad starting, hesitation, lumpiness, engine fault light? Take it back, find the mechanic who did the job, get your old cambelt and tighten it around his neck until his ears bleed. Just no excuse for not checking your timing marks Here's the job on an identical 1.2 Bravo engine. Water pump is lower right in picture
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX Last edited by Deckchair5; 01-06-2008 at 23:37. | ||
| | #9 | ||
| Re: Timing belt on stilo Thanks Deckchair5 for taking the time to put that together. I appreciate it and now know what i must do. Regards, Kieran
| | #10 | ||
| Re: Timing belt on stilo You can check in this page the timming kit for your car, Code: http://www.shop4parts.co.uk/index.cfm?action=catalogue.list
| | #11 | ||
| The modfather | No variator on the 1.2/4 or 1.6 yipeee ..is your car sounding like a tractor on start up then..if so yep its the variator and your wise to get it done the same time..
__________________ International man of mystery ![]() Wit ..sarcasm you get it all from me.. | ||
| | fiattech | Stilo | 1 | 31-03-2008 22:17 |
| | shiningliao | Stilo | 10 | 27-01-2008 09:58 |
| | amanda40 | Marea | 5 | 14-01-2008 23:09 |
| | johns | Stilo | 15 | 05-11-2006 14:56 |
